Bed Rattling
Tot
Tot
661
462
Des Arc, Arkansas
Not sure if this has been posted on here before, I feel like it has but I'm not sure. I need some help with adjustments on the bed to keep it from raddling. I tried tape on the latches but it made it hard to close.
Any help would be appreciated, pictures or point me in the right direction on another forum page. Thanks!!
266,470
I searched and cannot find the post but there are a few solutions and all worked. In a nutshell the metal hooks that hold the bed down are part of the culprit, some have covered them with a rubber tubing or black electrical tape / heat shrink that stops that one. Next is your doors that rattle at idle there is an allen head adjustment and rubber stop grommets that can be adjusted to stop that. Lastly is the Roof if you have one, and you can either put a little two sided tape between the parts that make noise, usually about mid-point where the roll cage front / rear joins up.
Tot
Tot
661
462
Des Arc, Arkansas
I searched and cannot find the post but there are a few solutions and all worked. In a nutshell the metal hooks that hold the bed down are part of the culprit, some have covered them with a rubber tubing or black electrical tape / heat shrink that stops that one. Next is your doors that rattle at idle there is an allen head adjustment and rubber stop grommets that can be adjusted to stop that. Lastly is the Roof it you have it and you can either put a little two sided tape between the parts that make noise, usually about mid-point where the roll cage front / rear joins up.
I'll try the tape on the bed latches again with a different tape. I got the doors stopped shortly after I got it. As for the roof I can see where the weather strip needs to go, but it hasn't been much of a problem noise wise for me.
Thanks Jackal!
Tot
Tot
661
462
Des Arc, Arkansas
Reactions: Scooterchris
amc019
amc019
480
592
Little Rock, Ar
I adjusted the latch part on the bed itself up to where I have to slam the bed down to get it to stay locked, but it sure doesn't rattle! the holes for the bolts on the bed are slotted.
Reactions: joeymt33 and Tot
Tot
Tot
661
462
Des Arc, Arkansas
I have to slam mine as it is, heck probably 60% of the time I have to reach in and push the lever down to get it to lock in place like it should.
A
AK_Centurion
271
330
Eagle River, AK
The seats also rattle in the down position, just found out the last ride, haven't messed with those yet.
39,104
This is what I did and works great.
adnoh
adnoh
106
115
I wrapped mine with electrical tape. It stopped rattles
A
AK_Centurion
271
330
Eagle River, AK
Can you tell me the battery cable heat shrink part number? I'd like to get some of that stuff.
I had some left over from an install years ago, I don't have a part number. Got it from local parts store. 1/0 cable, heavy wall adhesive lined is what I asked for.
walexa07
walexa07
396
380
Louisiana
Would 1/0 be close to 1" ID? I found some heavy marine grade adhesive lined shrink tube but it doesn't come in gauge sizes just fractions of an inch up to 1".
Waylan
Bayouownbeer
Bayouownbeer
786
1,061
Chauvin LA
I adjusted the latches on the bed up about 1/8" of a inch it makes it latch tighter on the runner pads helped a lot.
A
AK_Centurion
271
330
Eagle River, AK
Waylan
Looked at the wrap I have. It does .750"- .220"
walexa07
walexa07
396
380
Louisiana
Awesome - thanks for taking the time to look at that for me. My fix about 3 weeks ago was to find hose/tubing with the right ID and split it over the rod that the latch, then put good zip ties on each end of the split tubing. Works like a champ but my fear is that since the tubing is split it will eventually catch, pull off, zip ties break, etc. This shrink tubing over the whole assembly looks like a more permanent fix.
Waylan
Stauvo
Stauvo
633
910
Minnesota
Forgive me if I missed an attachment. Also someone here used black foam tubing, the kind pre slit up the side and fit a piece over the rear lateral seat backs then everything was tight between the bed and seat in the down position. That is how I remember that post.
