Boom!!! Power Commander now out for Pioneer!
HondaTim
HondaTim
203
40
Sweetttttttt ... now arched a arm lifts and exhaust systems and ill be happy.
63,622
Bryan 22 said:
What exactly will this power commander do?
If it works good, You will see a slight power increase. And more if you install a good filter and muffler.
Otherwise, It just burns more fuel.
HondaTim
HondaTim
203
40
Doesnt that mean that the governor will be raised ... no more 45mph?
HondaTim
HondaTim
203
40
Well when you said it would burn more fuel that kinda scared me lol.
63,622
What it does is control the injector to deliver more fuel at the right times. This will allow for power during those times. For example, a quicker take off. Stronger push up hills.....
Fuel millage will drop. A "balls to the wall" guy, could see it cut in 1/2.
HondaTim
HondaTim
203
40
Oh sh*t ... preciate it ... are you going to get one?
63,622
Idk. I want to try one. But I don't want to be the test dummy. $400 is a lot. I would want to make sure the improvement can be felt!
Reactions: Sgt_Dubie
HondaTim
HondaTim
203
40
Lol thats exactly how im thinking
10spoke
32
6
Hmf said sometime in May they should have there exhaust in production.
63,622
hondaslob524 said:
I wonder if that pipe will get rid of whatever is coming loose and causing the power loss in the exhaust!
Yes, It is the factory exhaust that is the issue. If you replace it with a aftermarket you removed the problem.
hondaslob524
hondaslob524
Upper Michigan (yooper)
So the new HMF will be a whole exhaust from the header back? It was my understanding that the part that is malfunctioning is further up into the exhaust system in a secondary baffle. One that wouldn't be replaced if the aftermarket muffler was just a bolt on using the existing mid pipe. I haven't looked at my exhaust that close to see if the stock can even separates from the stock exhaust.
63,622
Mid pipe is fine. Its the actual baffles inside the muffler coming loose from a crappy weld job.
There is like 5 or 6 of them from what little I know about this muffler. maybe more/less.
One will break loose and stop up the next baffle's exhaust hole creating more back pressure then the motor can handle. Thus slowing it down.
Yes, it does separate mid ways down.
hondaslob524
hondaslob524
Yeah Im thinking its going to be a future purchase for this guy. I just like how quiet the exhaust is now, never thought id say that after years of straight piping everything i own and running 5 inch on the duramax lol
