Commander XT shocks
d_b
d_b
302
240
Anything special about the grease? I didn't look close but I don't think there was any in the box.
Axle Grease?
Gear Oil?
Johnson's Jerking Lotion?
It is special. He always includes it. I buy from him for my CNC machines, great people to deal with. Johnson's Jerking lotion is also recommended for after the install and ride...On a personal note I like the unscented.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I bought the shocks from nick1993 they were in really good shape. The bushings look good. Put the fronts on. Raised the front about 2 inches. Now the 30s with the 3 in lift dont rub when going over bumps.
The only issue I have is the rear. I have a 3 in bracket lift on it. If I put on the rear shocks it puts the axles in a real bind. I am either going to have to turn the rear shocks all the way up or remove the lift from the rear and install the xt shocks and turn them up accordingly.
Get some Rhino axles, I bet they could handle the angles
HondaPower
39
32
Well the other issue is it will not fit in the garage. I already have to take the roof on and off for it to go in there. Adding the rear shocks will not let it go in. Small things.
I am going to turn up the stock rear shocks today.
G
green02crew
158
54
I had my stock ones turned up all the way. I could just fit in the garage with the roof on and it was a really rough ride. With the commander rears, preload all the way down, the ride was much better, especially for rear passengers but I have to take the roof on and off to get in the garage.
I saw your earlier post, are you trying to run commander shocks with a 3" lift as well? The commander shocks will give you the same amount of lift as the lift itself but with a better ride. Adding additional lift and the shocks will surely bind the cvs.
Reactions: Tflynn
HondaPower
39
32
Decided to keep the rear stock shocks and turned them all the way up. It passed the 5 gallon bucket challange!
20160517 192849
Reactions: joeymt33 and Tflynn
I'm still loving those tractor tires!
I'm loving the tractor tires too. I wish someone would measure the 30x10-14 for me.
I like the executioners you got too, they are similar to the tractor tread
Reactions: Tflynn
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Thanks Joe that's why I got em!
Reactions: TDos
7,145
27,187
OK the rears are installed. OH MY! WHAT A HUGE DIFFERENCE IN THE RIDE. even the wife could tell the difference.5ad91c9ef88933ee61c9d9e56c281960 before
63ab5803091e89fcb9dc269cafbae665after
Sent from my SAMSUNG-SM-N910A using Tapatalk
Wow, that's a big increase in ground clearance. Really cool
Sent from my iPhone 10s
Reactions: Tramguage1
7,145
27,187
This is with just the shock replacement
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
3" is quite a bit.
I hope I get to install mine this weekend.
G
green02crew
158
54
Does anyone have measurements of what the front gave from stock? Mine already had a lift on it and I didn't measure from stock height.
7,145
27,187
Here's what u had.9607575c202cdadfc6eaac6e41565c48before
C8a52562a76c956c8c3a8ff823e70d0bakter
7,145
27,187
Preload all the way down.
Trophy truck ride is a good discription of the ride
Gator
Gator
2,475
10,396
Louisiana
Just my luck. I got ready to do this install and my bushings are wrong. I think one of us must be dyslexic. I have a call in. Hopefully they will exchange these AND provide me with the grease.
Gator
Gator
2,475
10,396
Louisiana
Update: John called from Poly Bushings(?). He is sending me new bushings AND the lube. So... Looks like next weekend I'll be in business.
BTW: I did get the front shocks installed. Can-AM shocks are a direct replacement. They settled in at 2.75 inches higher than stock. I checked Toe-In before and after. Zero change. I'll try to send pics when this is complete.
scott
scott
1,212
1,354
lyman, South Carolina
Does anyone know of some fronts for sale? I would like some but I've only found some on eBay but they looked rough.
Gator
Gator
2,475
10,396
Louisiana
Try searching the Can-Am forums. That's where I found them.
