P700 Engaged but stopped & won't go!
2Track
2Track
21
45
2020 700-4m Was stored for winter inside. Started right up drove out of garage hit reverse an forward to line up with the trailer and all of a sudden it won't respond to forward or reverse when engaged, engine races and only moves just a little bit. Something in linkage? Transmission issue? 1800 miles and this is the first problem.
Mark in Northern Iowa
466
2,082
Floyd County, Iowa
kramnella.wixsite.com
First best guess would be weak battery, or mouse chewed wires.
"BUT, but it started right up." Do a battery load test to make sure.
Our Hondas will start with a weak battery.
Then other things stop working like they should.
Any flashing dash lights?
Have a good day
107,730
Start at post #6 If u figure it out dont be like Epstine and leave us hangin!
We also need pics of your rig. There isnt any of it yet. POIDH
107,730
@2Track did u ever figure out your battery issue? Might be related. You left us hanging on that one 🤣
You said u left it in storage, in our hard winters, prob no float or trickle charger huh?
2Track
2Track
21
45
Have a good day
Mark, I just left it set for now. I will be back to chocking things out tomorrow. I take the battery out over the winter and trickle it.
2Track
2Track
21
45
Guilty, I did forget to get back on my last issue. It wasn't a battery issue last year! Embarrassingly it was 100% operator error. Would you believe that it wouldn't start because I had it in drive and wasn't depressing on the brake? I had to eat crow that time. Just newbe dumb. Oh well.
2Track
2Track
21
45
20210427 162338
WagginTail
WagginTail
1,482
5,477
SC
Did you check the engine oil? My rincon got low one time and the engine would rev but it wouldn't move forward or reverse
107,730
$hit happens bro in both cases. Thanks for retracting your Espstine!
2Track
2Track
21
45
Update! I changed the oil and filter and apparently that's all it took to get back to normal. Working fine so far. Case closed. Will keep an eye on things for a few rides.
Reactions: WagginTail
Jerryg
Jerryg
10,846
87,438
NEPA
How did the oil and filter look?
