Front bumper removal
Psylas
Psylas
77
49
Anchorage, Alaska
Image Hi all, I'm trying to remove the front bumper so I can install my winch. Running into a problem with the two bolts underneath. I cannot get them loose. Anyone else run into this? Any tips on ideas on how to get then loose is much appreciated.
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
what tool are you using to try to loosen?
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
are they spinning or are they tight?
Psylas
Psylas
77
49
Anchorage, Alaska
They're on tight. 10mm wrench. Can't find my ratchet. About to go buy another. The bolts are starting to strip.
265,322
You need a 6pt, socket not a 12 pt. for a firmer grip and less likely to slip, may want to heat up the bolts with a LP torch, sometimes that makes all the difference in the world.
Reactions: Psylas
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
+1
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
sounds reasonable!
63,391
Just need to use a ratchet with a pipe on the end to break them loose. If all u have is a wrench... I can see how troubling it may be.
265,322
Well what you can do now is drill out the bolt and re- tap the hole to a larger size or install a heli-coil of the OEM diameter and thread pitch.
Psylas
Psylas
77
49
Anchorage, Alaska
That's my final plan. Will try some other methods first though. Thank you guys for all the tips! Can't believe this is giving me such a hard time...
swsebek
swsebek
2,854
5,828
pa
I just hope hes turning it the right way
Reactions: Hondasxs
265,322
Well it depends on what side of the equator he is on. :eek:
But left loosey, righty tightey is a good thing to remember, except on Honda flywheels they do have left handed threads. :D
Reactions: Psylas
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
ok striped try a vise grip maybe you will get lucky. if not you can use a drimmel tool with a wiz wheel (cutting wheel) and cut a line a cross to make a flat head screw driver slot and use a big flat head with a combo wrench for torque. after that weld a bolt and if that doesn't work then drill and tap.
Reactions: Psylas
