P500 Going to buy a p 500 and have questions
crewcabrob
crewcabrob
1,029
4,038
Omaha
I use the manual mode on 2017 mostly on tight trails, and like that it still does downshift automatically when slowing down in either mode. Don’t think the 2016 does that. A related thread. P500 - 2017 vs 2016. From a 2017 owner. The 2017 has a lighter green only used for that year. Its a little tank. If thinking about OEM accesories, check out HondaPartsKing for prices so you can be an informed negotiator with dealer..maybe throw something in the deal or at least the first maintenance service. Good luck, either P500 choice is a good one.
Thank you for the great info. I will for sure take a look at the accessories as I know I need to load it up with quite a few things.
Rob
Reactions: Bastardchild
RickMaynard
101
121
Arkansas
Thanks for all the replies everyone. Got everything set up the way I want with tires and switches for the lights and winch. Already a blast and these things are like tanks. Will climb anything!
Before the ride.
After the ride
I would invest in some straps that are more heavy duty for piece of mind. My straps are 1900# useful load and I use 3 of them for my P1000. It’s a bit of overkill but I never worry about them breaking. Just friendly advise.
crewcabrob
crewcabrob
1,029
4,038
Omaha
Rob
Hi all,
I went to my local dealer last weekend. The wife was semi willing to go since I just sold off my Suzuki Samurai
We looked at the 500, 700 and 1000. My wife's comments were pretty predictable: "I like this one, it has a cup holder.(p500)" "This thing cost as much as a car! (1000 LE)" and " How about this little one, it's a lot cheaper." So, even though I thought she would like the larger 700, she will was pretty much OK with the P500.
Not a single person came to help us while we were there climbing in the different models for 30+ minutes. I figured I would be swarmed by the sales guys when you pull up in a new Rover.
For those that have been in other 50" vehicles like the Kawasaki Brute and others, how would you say the ride is? Any others I should be looking at? I need it for general activities around the house: pushing snow, pulling down trees out of the way, moving dirt, mulch, logs … and of course a slow trail ride to watch the sunset.
I am very limited to 54" max on the width. So even with some bigger tires on the P500 I should be fine.
Thanks,
Rob
157,872
Hi all,
[/URL][/IMG]
Thanks,
Rob
The ride sucks but it's the smallest sxs on the market. You'll get a better ride from the other 50" machines but they won't fit it some of the tight spots that this one will...and they're not a Honda.
Reactions: Gassygordo
Mudder
Mudder
NTC Ambassador of Walls
11,343
84,383
@crewcabrob , For your pulling chores, seems like the low gears and clutch gear transmission on the P500 would work best. Had a polaris atv with plow and it took a toll on the belt drive. Not familar with the type drive on the others, but for low speed work and trails, the P500 serves me well as I like to be engaged as a driver and enjoy the paddle shifting. Just my thoughts (still owning a P500, 420 Rancher, Polaris 250, Polaris 400). Have not used the Polaris since getting the Hondas. Wife likes the power steering addition on the P500. Saw you recently joined, so if you test drive a P500 with auto, they shift hard off show room floor, but many post here on an easy adjustment to make it better, don’t let that deter you too much. JMO
Reactions: DaddyDubbs
crewcabrob
crewcabrob
1,029
4,038
Omaha
Thank you for the tip. There is a left over 16 at my dealer, so I may end up with that one if a deal can be made. I explained the shifting to the wife, and I am sure with just a few quick drives, she will have the process down.
Looks like this little beast is going to cost me a fair amount of money up front: P500, winch, windshield, rear cargo box from Strongmade, blade, wheels/tires, top... Bet I have way more than $12k into it quickly.
Thanks,
Rob
crewcabrob
crewcabrob
1,029
4,038
Omaha
I've read that people with larger tires and removing the rear sway bar, seems to help the ride a lot. Any other tips other than low PSI in the tires and then of course new shocks?
Rob
G
Gassygordo
302
1,025
Fillmore, NY
Hi all,
Thanks,
Rob
HEY, I sold my 87 Samurai to buy my P5!
906UP
906UP
13,098
122,253
da Yoop
Rob
I agree with this 100%, I think the tires were the best upgrade. A little larger....heavier tire helps tame the short gearing......smooths it out. I also removed the away bar but did it early on so I can't say how much it improved the ride. That said I've never been in a situation that made me second guess taking it off.
41,933
Hi all,
Thanks,
Rob
Take your wife for a ride through some bumpy terrain and she will change her tune. It's good that you are coming from a Samurai...it'll prepare you, but realistically, if you're limited to 54", you have no choice but a 50" machine. Not sure what a Kawasaki Brute is...unless you're talking about the BruteForce, but its hard to compare ATV's to SxS's...
Can't really comment on 50" vs 50", but the longer wheelbase of the others will make for a better ride while causing it to get hung up in the middle. Life is a compromise...
You grew up in Moab but moved to NB? No offense to NB....but WTF?
crewcabrob
crewcabrob
1,029
4,038
Omaha
Yeah, its a long story on the Moab move. I was born in California and have been slowly making my way across the country. I'm pretty sure my wife won't be happy until I'm buried in Florida. We go there three times a year now to vacation.
My wife rode in my Samurai 3 times in the entire time I had it. She has a blown out knee, so getting in was a struggle. Then the ride was an issue and the noise. It had a stock exhaust, but the Sami was a tin can with no insulation.
I'm trying to keep the sxs small and inexpensive. So, I'm not really looking at other brands right now. I've had good luck with Honda ATVs.
I appreciate the info guys!
Rob
207,989
Rob
Have you already bought it? Don't, it will cost you a lot of money for accessories and you will jump at any excuse to drive plumb across the states to ride some where new, HA!
Reactions: 500oneer
crewcabrob
crewcabrob
1,029
4,038
Omaha
No I haven't bought it yet. Our house on the acreage is still being built, we don't really need it until closer to completion. But yes, I assume this will end up costing between $12k-$14k all in.
Rob
Reactions: Chooglin
Mudder
Mudder
11,343
84,383
P500 seat is easy in and out. Took neighbor to ride after his knee replacement, no problems. Some sporty sxs with bucket seats might be harder.
Husker1
114
186
Nebraska
Rob
Rob if your in Omaha-ask for Kody at Dillion’s and get them to give you a discount for extras . I live in Omaha pm me if you have any questions or just need to bs. Terry.
crewcabrob
crewcabrob
1,029
4,038
Omaha
Thanks for your suggestion. I sent you a PM. I live in Elkhorn so Dillon's is right down Maple from me.
Rob
Husker1
114
186
Nebraska
Rob
Just had a good experience with him. His podium is right by the SXS on the lower level. Tell him I sent you. Terry
SchockSquad
Nebraska
Glad to see there's a few more P500's in the area, or soon to be. I'm about 6 blocks south of Dillon's. I got mine a few months ago across the river at Edwards. Thought about that 2016, but went with the auto transmission. Been working on accessories ever since.
