P1000 Heat from seat
NTCPrezJB
NTCPrezJB
President of #NTC
100,266
896,296
Canton, OH
Trigger send me link to order correct shield for 2024 pioneer 1000/5
Please
All the P1K5’s and 3’s will fit perfectly. There isn’t a difference between the models for any year (so far) in terms of the QuickShield fitting.
Reactions: trigger and -Bear-
StewB
StewB
662
3,071
Ordered thanks for all the advise
@tbounds02 - what they said 👆
I also bought a roll of adhesive firewall/reflective mat. It's the stuff people often use for vehicle acoustics, a bit like Dynamat, but much cheaper and watch the temperature range. Make sure it can take the heat of an engine compartment.
I opened everything up to get behind the angle/back part of the seat, washed everything with a degreaser, and stuck two layers of the stuff over that back angled section that otherwise lets the engine heat bake your crack. (Can I say that on the air?). The stuff isn't that expensive and you can cut and paste sections as you like.
It helped a lot, including for my dog that has to really tuck into the middle seat to be comfortable.
Also, here's a link to one of the prior discussions of the bilge v. radiator fan discussion.
Mine is a 2021 P1K5. I first installed a 4" bilge fan (put it back in the box), but then went with a generic, reversible Amazon, 7" radiator fan hung from a bar under the seat. I like the heat in the winter, but ride in southern Utah and want to blow the engine heat out of the back most of the time.
I have a reversible in/out blower switch. I don't have an enclosed cab, so I think I'm good with carbon monoxide:
1711141823109
The photo below is from the passenger side, and the OEM black rubber underseat cover is folded to the left.
My 7" radiator fan is hung below the seat on the flat metal bar upper right in the photo.
The fan came with vibration isolating springs, so I used them (shown). It knocks down the interior noise.
The slight angle towards passenger rear turns the air flow across the headers and out of the back.
View
Best.
NorthernJoe
NorthernJoe
325
1,247
Northern Ontario
so it’s not glued down? And by laying it over this the seat will still latch on top of it ?
View attachment 422505 View attachment 422506
If you want to add an under seat fan you will need to trim the deeper part of the centre under seat storage tray. Because the sides are tapered you can simply cut around the bottom about 1/2" up from the bottom and drop it back in from the top. A little black RTV and its as good as new. I also covered the bottom of this with Dynamat Extreme and Dynamat Hood Liner to help with noise and heat reduction
IMG 8879
IMG 8880
IMG 8881
Reactions: StewB
GovtMule
GovtMule
11,754
114,099
Tennessee
Just buy it…!!!
Reactions: trigger
Jerryg
Jerryg
10,552
85,520
NEPA
You could just wear a diaper.
NewHere2
NewHere2
Village Idiot In Training
35,543
302,689
High Plains of SD
IMG 0454
IMG 0453
Installed an 8” fan from Amazon. Very quiet fan.
Caution ! On the 22 and newer models with the plastic trays under the seat. Any mounting bracket you make needs to be spaced 1” down from the black brace bar.
Needed for clearance on the plastic trays. Of course this would depend on how you are mounting it.
Jankyeye
Jankyeye
520
2,249
Tampa, Fl.
That’s a slick mount!
RacinJasonWV
RacinJasonWV
WV
I see you’ve already ordered the Quickshield. 👍 It definitely helps and is worth the money. I still keep a windbreaker rolled up behind my back in the summer to help a bit more and can then wear it if the weather gets chilly.
I had a little trouble finding photos of it installed and therefore had some of the same questions as you. Which is why I made this thread to show how it installs.
Once you see how it sits over top of the plastic it all makes more sense.
