P1000 Heat from seat
tbounds02
36
105
Ms
  1. Looking to buy
I have a 24 1000/5 deluxe my first honda sxs .
Is it normal for heat to be coming from seat between bottom and back of seat when riding?
It is noticeably warm on my behind, it’s not even summer.
Mark in Northern Iowa
466
2,082
Floyd County, Iowa
kramnella.wixsite.com
Yes, it is normal, and a well known thing, just like EVERY other SxS, where you are sitting on top of the engine.
Ranger
Can-Am
General
BUT, there are some things that can be done to help.
Quick shield, and under seat fan/bilge fan
If you had a 3 seater, you can remove the engine and trans covers under the bed.
Really helped with my heat.
IF you are moving at a good speed, the heat gets pushed out the back.
Most trails and farm work, you are not moving fast enough to move the heat out.
Heat rises, and you are sitting on top of the engine.
That is why, if you read the other forums you see they do it as well, add some form of fan to blow the heat out the back.
Have a good day
toddvdh
toddvdh
1,073
7,080
Green Bay, WI
Agreed it’s normal. I didn’t do anything to eliminate it because it’s not a big deal in northern WI. I enjoy it 9 months out of the year. The other 3 months it’s really only too hot for a couple days.
A flip up windshield helps a lot
NorthernJoe
NorthernJoe
331
1,275
Northern Ontario
I switch my fan off for the winter, but it is definitely on for the summer!
StewB
StewB
677
3,130
It is normal when you're on top of the engine. Add the Kawi Teryx 4 to the list above of hot seat rides.
The two fairly easy solutions are 1) heat shields under the seats - especially right behind your butt cheeks, which seems to be the hottest part; and 2) a fan under the seat to blow the heat from the headers out of the back.
I have a reversible switch on my 7" radiator fan under the seat. I can use it to blow the heat out of the back and someday I'll finish installing the vents so I can blow the heat into the cab in the winter. I don't use heat shields, just the fan.
Search this site and you'll find a number of write ups about how to do either or both.
Good luck.
tbounds02
36
105
Ms
  1. Looking to buy
Mine is 2024 the heat shield material doesn’t fit 24 models it has one open hole in center has a thin plastic cover . I am sure that would be the place to mount a fan . Insulation maybe on underside of cover .
Does anyone have a radiator fan information ? Send me a link where to purchase
Reactions: NTCPrezJB
158,935
What heat shield material doesn't fit?
tbounds02
36
105
Ms
  1. Looking to buy
Quick shield , really any kind of mat material unless you line the boxes on sides
W
willieronk
30
123
MT
I had the same problem and started with the heat Quick Shield. Good guy to deal with. I found that some silver blanket fine tuning helped around the seat belt holes.
tbounds02
36
105
Ms
  1. Looking to buy
I only have the single cover in the middle the sides are open bins
Jankyeye
Jankyeye
570
2,536
Tampa, Fl.
It doesn't matter what your under seat configuration is, trays, storage bins, open space, flea circus, etc. The trigger shield lays overtop any of it.
1711133043326
Jankyeye
Jankyeye
570
2,536
Tampa, Fl.
No glue or trimming required, seat latches just fine. Hardest part is getting the seat back screws lined back up after install.
