Multi HID conversion.
solrus
solrus
1,629
2,511
Montana
I just installed mine in the p500. They are also straight out like yours but not quite as far. I was able to bend the wire down and get the cover back on...hope it wont damage the wire long term. I purchased the xentec brand for $22 on ebay. Super easy install, took less than 5 min. They look great but do flicker a little, not sure if this is normal or not.
I got OPT7 Bolt series kit
http://www.amazon.com/gp/product/B0118I9H5G?tag=sxsweb24-20
To help to eliminate flickering use these
HID Capacitors
http://www.amazon.com/OPT7-Capacitors-Warning-Light-Canceller/dp/B00J8QNNWY/?tag=sxsweb24-20
319,705
How far past the cover would you say they are
319,705
well I suppose it's good it came with a plug. As long as it seals good and you had a hole saw so it didn't booger it up bad I sure wouldn't be opposed to that it would still seem factory to anyone ever looking. Must just be slightly less room in the 500. You definitely don't want to crank over the wires as that would put massive stress where they enter the socket. If you do go that route put a very light layer of grease around the hole before the plug so it goes on easy and further helps to waterproof.
319,705
1cm seems like a lot more then I would imagine. That's a lot. I is the bulb all the way in? I'm not meaning anything but damn that's a lot! Never seen that seen them tight but...really check and make sure the rubber will stretch that much and seal if in you think it will I wouldn't worry but I'm definitely not a fan destroying anything even to win in one category. For the price and benefits it's worth a little but not if it allows water through
solrus
solrus
1,629
2,511
Montana
Will keep posted once finish install. Torn between heater, skid plate mods.
319,705
Very good get back:)Sometimes I hate the ever increasing urge to add goodies! These things are addictive. But so much fun
Reactions: Tflynn
solrus
solrus
1,629
2,511
Montana
No :), just those and done. I wanted all to be done before I hit real trails and dirt, snow.
319,705
are you able to run much coming up in your neck of the world? How well does your heater work?
sthomp54
sthomp54
375
Reactions: CumminsPusher
solrus
solrus
1,629
2,511
Montana
Thanks for the info. I drove it around tonight and didnt notice the flickering at all, think it was just because i was looking real close while shining on wall, stationary. I really like them, great upgrade for 20 bux!
was the HID kit relay connector perfect fit for p500 bulb power plug?
sthomp54
sthomp54
375
The plug fit but the clips wouldnt engage. The weather seal held it in pretty well tho.
mystic1219
mystic1219
191
202
Huge improvement over stock!
Uploadfromtaptalk1446297921728
319,705
Not too shabby for the price of a couple half racks of beer!:)
319,705
You just have to go without for a couple hours is all but then when you start back up you can at least see good:)
jay dawge
108
62
So if I buy these lights, they look good after two 12 packs of beer?
d_b
d_b
302
240
Everything looks better after that much.. Back on a serious note, I ordered the 5k and now dont know if that's what I want so I ordered the 6.5K, good thing is truck takes the same light so I guess it gets the leftover. I'll put one in both sides of the Pioneer for comparison and post pics.
jay dawge
108
62
I plow a 1000ft access rd, and my 350+ft driveway, and I am worried the headlights might not be bright enough for night plowing. I have been dragging my feet on doing the research on lighting. if there is an easy plug and play bulb or or kit I think I would prolly try that first. The road and driveway are very narrow so backing up requires some night visibility, on my kawasaki I I just used a rechargeble LED drop light stuck to the dump bed "via heavy duty magnets " seemed to work OK " so I will prolly do that again this year so basically it's just the headlights, I have never used HID before, stayed away because of the extra hassle associated w/HID's. I like to be able to change everything back to stock if I need to so I usually don't cut and splice.
