Multi HID conversion.
d_b
d_b
302
240
They'll be bright enough, just remember to aim your headlights. That's the main thing. As far as plug and play couldn't get any easier and yes you can go back, just unplug.
jay dawge
108
62
sounds like the P700 fits better than the p5oo, I will wait for now.
319,702
These kits aren't cut and splice at all. You take your bulbs out put hid bulb in and plug the setup in. That easy! They're under 30$ I'll see if I can find one that looks like the bulb will be slimmer. You can get accessory sub harness for back up light. It's made for backup alarm and in reverse it would light up.
Reactions: jay dawge
solrus
solrus
1,629
2,511
Montana
I like mine conversion too
Gator
Gator
The Most Unknown Member
2,474
10,381
Louisiana
I can't find the Opt7 with "866" bulbs.
Are you sure that is the right number?
solrus
solrus
1,629
2,511
Montana
Yes , positive http://www.amazon.com/gp/product/B0118I9H5G?tag=sxsweb24-20
pick 881 (862, 886, 894). It peferctly locks into socket, but as I pointed before the portion of the bulb where the wires come out is straight and you will need to cut out 3/4" up to 7/8" hole in the cover cap to allow to fit it and the bulb supplied with rubber plug that would fit very tight.
Another good experience with OPT7 , that I burned bulb when was installing and they promptly sent me another 2 bulbs, and even doubled them, because I emailed via amazon and via their web support, so I've got 4 bulbs :). They also replace for free all parts for 2 years under warranty.
Reactions: CumminsPusher
jay dawge
108
62
OK I ordered my hid kit last night, hope I got the right kit here is a screen shot:
319,702
Looks right. Apparently it's a little more dinking around in the 500 then the 700 or 1000 standard but doesn't seem like much more and it'll be reversible if needed. I'm sure you'll like the upgrade really a big difference. Throw pics up when you get done:)
jay dawge
108
62
Everything looks better after that much.. Back on a serious note, I ordered the 5k and now dont know if that's what I want so I ordered the 6.5K, good thing is truck takes the same light so I guess it gets the leftover. I'll put one in both sides of the Pioneer for comparison and post pics.
I ordered the 6k diamond white, just tried them out and I like the color, it will light up the snow banks very well.
jay dawge
108
62
Now I have to get the part #'s for plug n play wiring harness kit I will need for a reverse light. I might need to put a light bar on the front cuz the light is slightly blocked when the plow is in the up position.
heres the new tune box I got for the p5: Log into Facebook | FacebookLog into Facebook | Facebook
39,079
I did this mod today on my P700. It looks better and it's brighter but the pattern is terrible. Makes sense though as the housing wasn't made for this type of bulb.
E047dcc1ae086f24b9228ea77894861c
Joe
39,079
I got the OPT7 kit as shown above. I'll get a picture soon of the light pattern.
O
OutdoorEd
Do these models of HID require the capacitors? I just want plug and play, but can't seem to find the opt 7 6000 without the capacitors included.
solrus
solrus
1,629
2,511
Montana
OPT 7 does not list them but they did come with them but you will have no use for them, the system does not have any error messages or blinking problems.
So plug them and enjoy :) ( without capacitators). Use only two bulb and relay that they supply and two ballasts, but connect only ONE P500 bulb socket to the supplied relay. !
O
OutdoorEd
Ugh....I thought that the OEM plug from the 700 headlight wiring harness just plugged in......not prepared to add anything that would void the warranty for sure.
solrus
solrus
1,629
2,511
Montana
You got it wrong, the harness that comes with OPT 7 kit will not void your warranty, why it should? And yes OEM plug from p700 light it the right fit to that harness that has adapter. May be I call it differently (harness/relay) , but it must to connect all system together.
No1hedberg
No1hedberg
15
Question..How much power do these HIDs draw compared to stock. I want to eventually add light bars, winch, stereo, etc. I think I'm probably already overwhelming the electrical system. Will these help or hurt?
solrus
solrus
1,629
2,511
Montana
What is says if I remember correctly it draws 30% less power then regular bulbs. I did not notice any problem with lights on, no gear shifting issues, I've used winch with them also. I highly doubt you would.
I hardly image you using all gizmos at the same time, unless you gonna plow snow at night with all your lights on and having stereo bashing :))) so your neighbors know that a nice guy helping them out in the snow storm .
My voltmeter reads above 14 V when all works together (HID lights, winch) when p500 is running. Only thing that gave me a trouble was cheap portable electric defroster vent, that was a amperage sucker :). Only works with higher engine rpms.
39,079
Pics of the opt7 HID pattern
8802779a58b8cc3c7828918745358bc8
5c6eb448b43ce267762597e08eb77023
2bb6d3e5137e0cd4c7881f6fef100e21
O
OutdoorEd
Joe
Is that the Opt7 conversion kit or is it the other one that's listed? Plug and play?
