Multi HID conversion.
Know off the top of your head what bulb fits an 08 Silverado? I hate the lights in my work truck so why not?!
319,711
B1f584ea5b4a3619911a9fc82de216cb
Sent from iPhone
Reactions: joeymt33 and JTW
319,711
Just looked it up. Looks like H11. So type in that and hid kit.
Reactions: JTW and joeymt33
39,079
I don't particularly like yellow light.. So I'm going with the 5k. I love the headlights in my new F150.. I'm going to have to see if I can find what they are.
What year f150? HID or halogen? My '14 f150 has approx 4300k.
I use 3000k for the fogs.
556cc4416ab248da0dae5548657b7f6d
SIGNATURE:
Quote by DrFubar: joeymt33, this could be your next signature: "I should be more understanding. I should know by now that a little hill to me probably is a big hill to you.;)"
319,711
Just look up bulb type and eBay or amazon that followed by "hid kit" lots of brands are ok I'm sure but very good luck with xentec so far. Gm might require a code cancelling unit I'm not positive you'd have to look that up. Pretty sure ford is still good.
Reactions: JTW
39,079
While we are on the topic of tint.... this is 4300k vs 6000k.
Bdcd9ad94cc0f659d22294acc186b3d1
I don't think that the wood is naturally grey.
Or leaves....
1c10aa16101eb3ad240254d04b8a4a21
SIGNATURE:
39,079
Probably 4300-5000. Those trucks do have good headlights.
I haven't sat behind the wheel and experienced the new LED head lights though.
SIGNATURE:
Reactions: CumminsPusher
SIGNATURE:
It's freak'n awesome! Very noticeable between the two trucks!
35w or 55w and what's up with the high/low Bixion and such? Will these dim and brighten in a truck like normal lights?
319,711
If you're truck requires dual filament bulb, Highbeam and low beam from the same bulb then you can use bixenon. Hid doesn't have the ability to dim or brighten so bixenon uses an electo magnet and a reflector to change light output. Works well however can vibrate and look like a loose housing over time for off road applications.
35 hid is far brighter then 55/60 halogen but you can go 55,75 or even 100 hid but the last two can melt your housing if plastic and you get flashed by oncoming traffic with above 35 usually but for 55 you can aim the headlight down just a little and be ok
Do you use 35 or 55 in your Honda?
319,711
I've got the factory led housing but had thought about going to the non deluxe housing for hid. I didn't use 55 on the Can-Am or p700 because we are street legal and travel highway occasionally. You could get by though. If you're only off road then go 55. 55 will put out probably 4 times the light as factory pos.
Reactions: JTW
That's what I needed to know! Yeah, we can't ride on the roads here anyway.
319,711
They are bright! Watt for watt in the same housing size hid is brighter then led. We've converted all our dirt bikes truck bus snowmobiles everything. The 1000 is the only thing we have without hid and I miss them for the headlights. You probably saw at the very start of this thread our old 700 is pictured with them in 6k. The pos on the trailer is 35w 5k
Sent from iPhone
Reactions: JTW
7,138
27,125
I just finished installing a HID kit on my Pioneer as well. Took 15 minutes to do both sides and looks 1000 times better! Just in case you can't tell, stock light is on left and HID is on right. I ordered mine off of Amazon for $40 with overnight shipping (link: http://www.amazon.com/gp/product/B008YFTZMC?tag=sxsweb24-20 ). They're the 880 bulbs in 6k color.
How have the HID bulbs done for You? Thinking about doing this to my 700-4. Looks like the color is very similar to the lite bar.
Sent from my SAMSUNG-SM-N930A using Tapatalk
L
longsidelandry
22
Delcambre, LA
They're awesome! Holding up great and they match the light bars damn near identically.
Sent from my SM-G900V using Tapatalk
