P1000 Honda Auxiliary Fuse Panel and True Dual battery isolator
AmBulls
AmBulls
39
Pennfield, NB
Hi, I’m in the process of installing a True dual battery setup. I have the Honda Auxiliary fuse panel already installed on my 2022 1000-5 Trail. Will this work?
Thanks
89CBB35A EF85 43FE 907C A0521066D948
Scoop
Scoop
4,250
15,927
  3. Talon R LV
Looks about right. Most energize the Stinger with a key-on harness from the 12V socket, but as long as your existing fuse panel puts out 12V when you want it (e.g., key-on), that works, too. Many install a DPDT switch so that they can power the AUX fuse panel and all attached accessories *either* when the key is on OR when the switch is in the AUX position, but not required.
Welcome. Oh, and you better post up some pics of your machine or it doesn't exist! The local sheriff will be around these parts to remind you, too.
AmBulls
AmBulls
39
Pennfield, NB
Thanks for the info!
Reactions: Remington
P
packer58
306
925
N. Cali
You may also want to consider installing a pos and neg buss bar to help eliminate stacking wires on your battery posts.
The Aux/Off/Key On switch sold in the club store is a great addition and gives you a lot of flexibility on how you power up your accessories.
Wisco-Tango
Wisco-Tango
73
248
Fisk, Wisconsin
@AmBulls if you are using the OEM Aux fuse panel it has it's own trigger wire that essentially performs the same function as the Stinger. See the connection circled below. There is a trigger wire as part of the harness needed to implement this fuse panel that ties into the Key on harness taped up under the hood.
1680618860510
All you would need to do is wire the isolator and the second battery in as you show but eliminate the stinger and run the positive and negative from the second battery to the Aux panel. As @Scoop mentions you can also wire a DPDT switch to allow use of stuff connected to this panel with the key off.
Reactions: Remington and Scoop
AmBulls
AmBulls
39
Pennfield, NB
So, I have used the trigger wire for my oem wiper. As this is already hooked up, can I just run the pos and neg from the aux panel to 2nd battery?
Thanks!
Wisco-Tango
Wisco-Tango
73
248
Fisk, Wisconsin
Thanks!
In short yes, just make sure to include the isolator between the first battery and second as necessary and ground everything back to the machine ground.
Reactions: AmBulls
HighboyPioneer
17
15
PNW
  1. 1000 6 Crew
Good info thanks. I too am wiring up a dual battery with OEM Honda fuse block. Has anyone figured out how (where?) to wire the True Isolator to crank side of ignition?
HighboyPioneer
17
15
PNW
  1. 1000 6 Crew
Starter wire, or starter relay wire.
Most don't install this.
Am I correct in understanding that it allows both batteries to help with start?
HighboyPioneer
17
15
PNW
  1. 1000 6 Crew
No. it is a DISCONNECT.
Its job is to disconnect when craking to protect the second circuit if wanted.
Ah okay. Thanks for the clarification.
HighboyPioneer
17
15
PNW
  1. 1000 6 Crew
I’m working on my new 1000-6. Unwrapped the factory key on power from the blue tape but get no voltage out of it. Does it come hot or do I need to fuse it somewhere?
HighboyPioneer
17
15
PNW
  1. 1000 6 Crew
Single wire on the driver's side?
Its key-on hot.
Mine isn’t….ugh. It’s dead. I’ll make the dealer sort it out when I have them do the initial 20 hour valve service.
HighboyPioneer
17
15
PNW
  1. 1000 6 Crew
Well, I don’t mind mentioning my dumb mistakes. Maybe it will help someone as dumb as me. So, I initially wired up a stinger to my OEM fuse block and did a jumper fuse for key on hot, because I didn’t know about the factory key on hot. Then I learned about factory key on hot. Well, if you have a jumper fuse installed, the factory key on hot is disabled. I finally thought to remove the jumper in #5 and sure enough it works. Anyways, now that I know the OEM fuse has an essential isolator built in, I removed the stinger and jumper in #5 and all is well in the world. The OEM key on hot splitter works great and allows me to run to OEM fuse block and AUX/MAIN battery display. I like to do things the hard way obviously. Thanks for the help here.
Reactions: CID
HighboyPioneer
17
15
PNW
  1. 1000 6 Crew
20 hour valve service?
Dealer said it’s crucial. Rest of the services are not crucial. They only recommended having the dealer do the first service. Showed me valves from guys that skipped the service. They had close to 1/2” elongation on valve stem. They want $400 to inspect and if one time adjustment is required then they want $700.
  • Wow
Reactions: CID
