P1000 Honda Introduces Pioneer 1000 Limited Edition (LE) Models with I-4WD
207,989
If I had a sure fire thing, I would certainly invite you up. It has been a pretty ruff year with all the weather fronts to find any consistency this year.
Are you talking about ice thickness or affects on the fish bite? We just to fish in Canada two weeks every year in the Summer, I have talked to fishermen up there, that were there during ice out, they told me stories about casting up on the ice with a spoon, reel as fast as you can and catching some really nice Lake Trout? I would love to experience a full year of fishing up North!
207,989
I can be adopted! HA!
W
Winterrider
17
31
North.Dakota
No, ice thickness is a good 30" on most lakes. Just so many different weather fronts has made for a very unpredictable bite this year.
BigOL3
BigOL3
2,994
8,919
  • From Talon HQ
    Brian Rash
    14 mins
    Ok I have a question here. I pinched a brake line a few weeks ago and it has a small leak now. While I was waiting on my replacement line I went on a ride and just kept checking on my brake fluid. Brakes got soft and 4wd stoped working. Does this mean that 4wd won’t work with out the braking system because of the ABS I4wd ?? Or do I have a different problem?
    11
    5 Comments
    Like
    Comment
    Comments
    • Nc ocAQkgkYMIU1MF5m6hO JxKSzFQqIG1tDwt8pi1z 30cWCyzx0zI2cOCFKw3t0Yw X3r4 nc htscontent atl3 1
      Chris Sukeena It's using the brakes to stop wheel spin, so if the brakes are soft the system won't work correctly.
  • Nc ocAQlMcxTr0gYVr7XR88GZBFcDPj8w ADIi84enWTRn8pb7 ApzgPCb qLhk2VgrscQro nc htscontent atl3 1
    Frank Davis Pinch the line with vise grips
  • Nc ocAQm6a xUqvq2FFY X96oiJCeaTrfdTD27bkZoHV3uONtE8vtJlaKGGamkaFdVR mgiw nc htscontent atl3 1
    Brian Rash Yes the 4wd system just flashing on the dash and it doesn’t pull on either side in the front. It stays in 2wd
    Frank Davis Cancel last comment
  • From Talon HQ
    Brian Rash
    14 mins
    11
    5 Comments
    Like
    Comment
    Comments
    • View attachment 137106
  • View attachment 137107
  • View attachment 137108
  • View attachment 137109
Moral of the story... Honda should have used stainless lines like a f***ing factory popo has! And anyone with an i4wd should buy @jak9922 stainless lines! @Cuoutdoors
320,433
christ! i need to get ahold of a talon brakeline now! i said it from the leaked photos when i seen rubber lines
Heck I was quick enough to get your lines after a brake issue and yet we still had 4wd and easily made it back out. If I had a rig that the 4wd system was brake dependent I would definitely buy them beforehand.
Btw nice job on those lines!
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
i4wd is 100% brakeline pressure sensitive! when you have rubber lines that are weak and "balloon" and weak!..... thats just asking for failure... someone have honda call me! ill put them on hold so i can make some money
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I've been meaning to track down "the break line guy".... PM me some info please so I can get some ordered.
Vikes79
Vikes79
SKOL!
10,984
106,621
South Dakota
  2. Talon X4 LV
Lol
No i4wd due to brake lines.
Potentially leading to getting stuck due to the brake lines.
Nice.
Reactions: BigOL3 and JTW
Kilo427
Kilo427
1,543
6,439
Every pioneer I help my friends build I have them use Jaks brakes lines! I tell them my experience and why they are important I suppose I can add now that on some models your 4wd will go out without them.
hammick
35
55
Montana
I have Eaton Truetracks in my built up Wrangler. I think they operate similar to the I-4 system. I didn't want lockers because the Wrangler will see of lot of snow packed and icy roads. The Truetracks are working all the time and are seamless. Driving on snowy or icy roads with locked differentials is a good way to get thrown into a ditch.
I would agree that if I had to do a crap my pants climb with steep drop offs that I would choose a car with lockers if I had a choice. But I'm guessing the car with the I-4 would get me to the top also.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
so what if the hill assist light does not go out?
When you push the button It's supposed to turn on for 3 seconds then go off. It holds the brakes on.
Is it on as soon as you start the machine?
jgremaux
5
montana
yes soon as the unit key is on then light comes on and says on
