P1000 Honda Pioneer 1000 Tire Pressure?
What Tire Pressure do you run on your Pioneer 1000? Vote twice - Front and Rear!
  • Front - 0-8
    Votes: 24 5.7%
  • Front - 9-10
    Votes: 68 16.2%
  • Front - 11-12
    Votes: 99 23.5%
  • Front - 13-14
    Votes: 174 41.3%
  • Front - 15+
    Votes: 51 12.1%
  • Rear - 0-8
    Votes: 21 5.0%
  • Rear - 9-10
    Votes: 53 12.6%
  • Rear - 11-12
    Votes: 83 19.7%
  • Rear - 13-14
    Votes: 176 41.8%
  • Rear - 15+
    Votes: 67 15.9%
  • Total voters
    421
DAV11
DAV11
105
194
Minnesota
I was wondering what tire pressure people are running on their 1000-5 deluxe? I'm not rock climbing or anything like that - mostly dirt roads and some trails.
Thanks
Tim
------ Edit by @Hondasxs
Added a poll. Vote twice. Front and Rear!
Honda recommends:
Front 13 psi
Rear 14 psi
Also see:
Pioneer 700 Tire Pressure? | The Honda Side by Side Club!
P500 - Pioneer 500, What Tire Pressure do you run? | The Honda Side by Side Club!
I read a post on here that if you want to take the sway out of the Bighorns 2.0 use 18 pounds of pressure.
208,013
Yep. It was in the P1 Nascar thread, helps with ground clearance also. That may have been posted by @JACKAL , he run's quite a bit of air pressure?
Reactions: DAV11
rickoshea
now i just crank my shocks up a click or 2 if i'm running hard.no more messing with tire pressure.i just run them at man. recommended .
Reactions: DAV11
265,559
I run 14-15 psi, saves on pinch flats and helps with high speed handling getting place to place.
Reactions: JenElio and TripleB
208,013
Hey Old man? You getting around any better? Best wishes!
208,013
Ok, lets look at @JACKAL 's statement , high speed handling, he has no venue in the high speed discussions, I like to ride with him because there is no high speed stuff involved, Gina would probably take his head off at shoulder height if so. I have a lot of fun with this group, just my speed!
Reactions: Plowboy1466
AZRocks
AZRocks
111
217
Phoenix
FWIW, I'm running 28x10R14 STI Chicane tires and keep them at about 14 psi for Arizona trails. When I tried around 10 psi the steering was uncomfortably sluggish, especially above 40 mph, especially on pavement. I will only drop the pressure if I am going to spend time in sand (not my bag), or to get myself out of something like a steep loose rocky climb or wet conditions where I need traction.
mshaken13
7
14
west Virginia
personally alot depends on the tire, the terrain your on and the weight your hauling if any at all the stock tires i usually ran around 15psi and personally i dont agree with oem recommended psi and dont feel that they equip the unit with heavy enough tire for the weight of the machine i feel they are atv tires but tire manufacturers are starting to design tires that are designed more for the heavier machines .I run truck tires and are happier with the results of them never got a aggressive enough tire but i got 9k miles out of them im due for a new set this time im going with the super swamper tsl
PJon
PJon
760
3,055
Arizona
@TimL Thanks for starting this topic. Should of already had one going!
I added a poll and OEM specs to your post.
Edited the title and added some other links.
As for me.. I haven't decided yet. Keeping them at 13/14 until I get some more seat time.
If you’re still running the stock 4 ply’s stick with 13/14 psi recommended by Honda. If you’re running 8 ply tires, you can drop them down to 10-11 psi without worry and I run these pressures for pavement, dirt roads and rocks.
Wellzy
Wellzy
269
899
SW Wisconsin
Factory tires, I go 2 pounds over front and rear to just harden them up a little, wear more in the center. Only pavement for me with very little else, gravel or grass.
bumperm
bumperm
1,848
6,646
Gardnerville, NV
175 psi for me . . . no need to buy bigger tires and wheels that way. I'd try higher, but that's as high as my compressor goes.
Warning, always wear helmet, goggles, hearing protection, and full body armor when airing up tires. Make sure other people are at least 100 yards away. Workmanship is so poor on tires nowadays, that you can never tell when one of 'em is gonna blow.
Cellblock70
Cellblock70
44
210
Tennessee
8 ply Evil tires with bead locks and WE shocks.
Trail riding 8 psi - with soft shock setting at 4
Road 15-16 psi, and click shock setting to 16 (stiffens the ride).
Higher psi minimizes surface contact on the road, less wear. Shocks have less body roll on curves at higher speeds.
Wellzy
Wellzy
269
899
SW Wisconsin
I changed my stock Bighorns to 3 pounds over, front and rear. 16 front, 17 rear so the 1 pound difference is still honored.
Reactions: JenElio
ODAMO
ODAMO
1,177
3,203
Ohio
Kind of an old thread, 2022’s list 20 psi front and rear.
My book says 18 psi frt/rr for the 2022. It seems too much to me. I'm gonna give 15 a try.
I have the 3, the 5 is 20 psi. Both seem rock hard
