Talon Honda Talon Full Specs - Honda Talon R vs Honda Talon X
64,288
Upload 2018 11 27 20 52 59
Full Specs in text below
[parsehtml]<table class="table" border="1">
<tbody>
<tr>
<td><strong>Model</strong></td>
<td align="center"><strong>Talon 1000R</strong><br> (SXS1000S2R)</td>
<td align="center"><strong>Talon 1000X</strong><br> (SXS1000S2X)</td>
</tr>
<tr>
<td align="center"><strong>ENGINE</strong></td>
<td colspan="2">&nbsp;</td>
</tr>
<tr>
<td><strong>Type</strong></td>
<td colspan="2" align="center">999cc liquid-cooled Unicam<sup>®</sup> OHC longitudinally mounted parallel-twin four-stroke; four valves per cylinder</td>
</tr>
<tr>
<td><strong>Bore x Stroke</strong></td>
<td colspan="2" align="center">92.0mm x 75.15mm</td>
</tr>
<tr>
<td><strong>Compression Ratio</strong></td>
<td colspan="2" align="center">10.0:1</td>
</tr>
<tr>
<td><strong>Induction</strong></td>
<td colspan="2" align="center">Fuel injection, 46mm throttle bodies</td>
</tr>
<tr>
<td><strong>Ignition</strong></td>
<td colspan="2" align="center">Full Transistorized</td>
</tr>
<tr>
<td><strong>Starter</strong></td>
<td colspan="2" align="center">Electric</td>
</tr>
<tr>
<td><strong>Driveline</strong></td>
<td colspan="2" align="center">Direct front and rear driveshafts</td>
</tr>
<tr>
<td><strong>Transmission</strong></td>
<td colspan="2" align="center">Six-speed automatic DCT + reverse and high/low sub-transmisson</td>
</tr>
<tr>
<td><strong>Clutch</strong></td>
<td colspan="2" align="center">2-Multiplate Wet</td>
</tr>
<tr>
<td align="center"><strong>SUSPENSION</strong></td>
</tr>
<tr>
<td><strong>Front</strong></td>
<td align="center">Double wishbone; 17.7 in. travel, Fox Podium 2.5 with Quick Switch 3</td>
<td align="center">Double wishbone; 14.6 in. travel, Fox Podium 2.0 with Quick Switch 3</td>
</tr>
<tr>
<td><strong>Rear</strong></td>
<td align="center">4+ Link trailing arm; 20.1 in. travel, Fox Podium 2.5 with Quick Switch 3</td>
<td align="center">3 Link trailing arm; 15.1 in. travel, Fox Podium 2.0 with Quick Switch 3</td>
</tr>
<tr>
<td align="center"><strong>BRAKES</strong></td>
</tr>
<tr>
<td colspan="2" align="center">Hydraulic w/ two 250mm discs; Electronic Brakeforce Distribution (EBD) system</td>
</tr>
<tr>
</tr>
<tr>
<td align="center"><strong>TIRES</strong></td>
</tr>
<tr>
<td colspan="2" align="center">28x9x15</td>
</tr>
<tr>
<td colspan="2" align="center">28x11x15</td>
</tr>
<tr>
<td align="center"><strong>MEASUREMENTS</strong></td>
</tr>
<tr>
<td><strong>Length</strong></td>
<td colspan="2" align="center">123.9 in.</td>
</tr>
<tr>
<td><strong>Width</strong></td>
<td align="center">68.4</td>
<td align="center">64.0 in.</td>
</tr>
<tr>
<td><strong>Height</strong></td>
<td align="center">75.6 in.</td>
<td align="center">75.3 in.</td>
</tr>
<tr>
<td><strong>Seat Height</strong></td>
<td align="center">28.3 in.</td>
<td align="center">28.0 in</td>
</tr>
<tr>
<td><strong>Ground Clearance</strong></td>
<td align="center">13.0 in.</td>
<td align="center">12.7 in.</td>
</tr>
<tr>
<td><strong>Wheelbase</strong></td>
<td align="center">92.7 in.</td>
<td align="center">87.6 in.</td>
</tr>
<tr>
<td><strong>Turning Radius</strong></td>
<td align="center">21.3 ft.</td>
<td align="center">17.7 ft.</td>
</tr>
<tr>
<td><strong>Fuel Capacity</strong></td>
<td colspan="2" align="center">7.3 gal., including 1.1 gal. reserve</td>
</tr>
<tr>
<td><strong>Cargo Bed Capacity</strong></td>
<td colspan="2" align="center">299 lbs.</td>
</tr>
<tr>
<td><strong>Curb Weight<sup>*</sup></strong></td>
<td align="center">1,545 lbs. (1,548 lbs. CA)</td>
<td align="center">1,490 lbs. (1,492 lbs. CA)</td>
</tr>
<tr>
<td align="center"><strong>OTHER</strong></td>
</tr>
<tr>
<td><strong>Colors</strong></td>
<td align="center">Pearl Red; Pearl Green</td>
<td align="center">Pearl Red/Metallic Grey; Metallic Grey/Metallic Blue</td>
</tr>
</tbody>
</table>[/parsehtml]
Full specs? Shouldn’t HP be considered a spec?!
Reactions: lee and BWAF
