P1000 Honda Water Ingestion Fix
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,601
Ridgeway, SC
I just installed these new parts on my '16. I am actually fairly impressed with them. The block off plate has a foam gasket on it and unlike the original cover, the new one has a foam gasket that bears against the rib on the platform that it clips into. Not as good as a true snorkle, but one heck of an improvement over the original design.
DPort
DPort
170
266
Lincoln, ME
This is the best I can do... snorkels are illegal in Maine and the game wardens will check when they stop you.
Reactions: AZhunter
jawquin
jawquin
299
652
Indiana
on my 2017 the MFD date is on the frame under the back of the bed you can see it over the rear passanger side tier the MFD is on the vin number tag in small print.
Thanks tbaker. I found it. Looks like May 2017
20170718 220341
Reactions: AZhunter
Elkhunter
Elkhunter
345
453
Minnesota
That's good to know. I just ordered the upgraded parts today!
Plumber101010
Plumber101010
597
584
Western NC (Hayesville)
Radiator hose is probably the easiest that I've seen. Which is why I went with that
What size hose clamp is that?
And the more that I look at it, is anything really being achieved by doing it that way???
Doesn't seem to me it would do a whole lot of good depending on where the water goes when you happen to splash through it or plop in it and throw it up in that area?
I mean maybe, but only if because some kind of way, the water is being specifically channeled to the intake area because of the way it's all designed under there, but all in all it doesn't seem like its accomplishing too much??
Reactions: AZhunter
320,582
It's sucking from the back rather then front so most splash will push by. Won't help swamping but will probably help the tire splash some.
Reactions: pct and AZhunter
Plumber101010
Plumber101010
597
584
Thinking I missed something, I went back through this whole thread and I haven't seen any kind of a part number or an order number for the entire retrofit kit?
The first couple of posts show separate part numbers but isn't there something like:
"2016 Honda Air Intake Retro Fit Kit?"
Or in CP's case
"2016 Honda Stuck It Up CP's Intake" kit?
320,582
"2016 Honda Complete Air Intake Retro Fit Kit?"
Or in CP's case
Lmao you make me chuckle!
Plumber101010
Plumber101010
597
584
Thank ya Bubba! Wondering now if some company is going to come along and clone it and start selling it like that?
If anybody read the pre-edited post it's because I looked at it and realized how difficult it would be for somebody to clone it on their own :)
Elkhunter
Elkhunter
345
453
Minnesota
Or in CP's case
2fbc4361299f3017d461868138d33257B67cbba94d56dc04f40867d3c1d59cae
