P1000 i4wd vs lockers
Jerryg
Jerryg
10,954
88,230
NEPA
Proxy image
toddvdh
toddvdh
1,078
7,117
Green Bay, WI
267,227
Hey @CumminsPusher , remember back when we first endured this debate. Seems like everyone on that i4wd bandwagon back then now has a KRX. Interesting ain't it.
Not everyone, some know how to use the I-4WD, it does prefer being driven a certain way. Those who can do those who couldn't KRX 🤷‍♂️
bumperm
bumperm
1,852
6,658
Gardnerville, NV
Seems to happen when they get a front tire off the ground crawling rock ledges and when the I-4WD takes over it throws the front end over off of intended line and there stuck?????
Could be wrong here, as I said, I'm no expert, but I try to be logical. Either machine, one front wheel off the ground, should behave the same. The front diff is locked on one so the in-the-air wheel will turn as fast as the on-the-ground wheel. With the i4WD, the in-the-air wheel will be stopped while power is applied to the opposite front wheel. In this situation, what would cause either machine to pull off to either side more than the other?
208,029
You tell me, I'm at a loss, the tire that was off the ground was spinning and the one that had contact wasn't pulling, when it finally adjusted and you know the rest. Been thinking about the air in the brake system causing the I 4WD to react slow??????????????? Another member stated this?
Russ989
Russ989
22,601
146,866
Was thinking about trading in my 21 on the 22 trail but I'm curious about the i4wd. My deluxe doesn't have it and I can't get the trail without it. I use my pioneer in my woods often climbing steep grades where you need all 4 wheels pulling and even then sometimes that isn't enough. Will the i4wd do that or is it not actually a locker in the front and rear?
Diff-Lock is king! I-4wd has its place but is not a suitable replacement.
