KFI has winch mounting plates!
41,749
Don't see this posted anywhere yet, but looks like the aftermarket is starting to get stuff out for the Pioneer.
1st up: The badly needed winch mount from KFI. 1/5 the factory price...
http://www.ebay.com/itm/Honda-Pioneer-W ... be&vxp=mtr
Product Information
Brand new "KFI" Winch Mount for the following Honda UTV's:
2014 HONDA PIONEER 700 and 700-4
Designed to work with the following Winches:
KFI: ST17 / S2000 / A2500 / A3000 / U4500 / U4500w / SE25 / SE35 / SE45
WARN: A2000 / A2500 / U2500 / 1.5ci / 2.5ci / 2.5ce / 3.0ci / 3.0ce / 3.0s
WARN: RT15 / RT25 / RT30 / XT15 / XT25 / XT30
WARN: RT40 / XT40
WARN: Vantage 2000-4000lb
WARN: ProVantage 2500-4500lbs
RAMSEY : ATV2500 / ATV3000
SUPERWINCH : Terra25 / Terra35 / Terra 45 / LT2000 / LT2500 / LT3000
MILE MARKER : PE2.5 / PE 3.5 / VMX2.5 / PE2000 / PE3000 / PE2500 / PE3500
CYCLE COUNTRY : Work Power 1500 and 2500 / Powermax 2500 and 3500
BADLAND : 2000lb #68146
- Requires the correct Fairlead with a 4.875" Bolt Pattern (available if needed #ATV-RF)
- Listed Models come with incorrect ATV Roller Fairleads
BADLAND : 3000lb #68145 / 5000lb #68144
CHAMPION : C10013 / C10014 / C10018 / 10020 / 10024 / 12053 / 12503 / 13501(reqires rollers) / 14061
CHAMPION : 14501 / 14551 / 14552 / 40252 (4500lbs)
CHAMPION : 10028 / 10032 / 12001 / 12002 / 13001 / 20049 / 20051 / 20249 / 30045 / 30145
CHAMPION: 14001 and 14061
KEEPER CORP. TRAKKER : KT2500 / KT3000 / KT2500C / KT3000C / KT4000 / KT4000C
KEEPER CORP. TRAKKER : KT2000
- Requires purchase of a roller Fairlead (KFI #ATV-RF)
SMITTYBILT : XRC 2.0
SMITTYBILT : XRC 3.0
XGEAR: X3000 / X4000
- 4-Hole Standard (3.00" x 4.875" bolt pattern)
VENOM: 2000 / 2500 / 3000 / 3500 / 4000 / 4500 / 5000 (Hardcore Series)
- All with 3.00" x 4.875" Bolt Pattern mount-up
- All with 3.00" x 6.600" Bolt Pattern mount-up
Possibly Many others with the below standard Mounting patterns (call to confirm)
- 4-Hole (3.00" x 4.875" bolt pattern with Rollers that are 4.875" bolt pattern)
- 4-Hole WIDE (3.00" x 6.60" bolt pattern with Rollers that are 6.600" or 6.000" bolt pattern)
- 2-Hole (3.10" with Rollers that are 4.875" bolt pattern)
Specifications:
100% MADE IN USA
Constructed of 3/16" steel
Unlike all other mount competitors our mounts are metal bead blasted before they are powder coated for the best possible finish prep.
Powder coated black for supreme durability
Very easy to install
Complete installation instructions included
All mounting hardware included
Satisfaction guaranteed
Roller fairlead and winch not included
F
foggy
108
0
I got one coming. The price is right.....and I think KFI makes pretty good stuff. Far cheaper and better than I can do it. ;)
G
GulfCoast
47
0
Now the only question is, if'n I get one, who can I get locally to hook it up?
randi 58
86
107
I got one coming too .ill hook it up
F
foggy
108
0
The mount looks straight forward. Not sure about your winch....but they aint that tough for the average guy with a few tools.
fishin2Dmax
fishin2Dmax
186
32
DG Rider thanks for the information on the Pioneer Winch Mount. I too have ordered one. It looks to be sturdy enough, but if it isn't, it's inexpensive and should get me through the winter. I'm hoping Warn comes out with an integrated winch and front bumper combo at some point.
W
Westtnpioneer
Edjumacated
350
603
West Tennessee
My plate should be here on Friday. I also ordered the se45 winch.
Let me know how the SE45 works out.
I like the look and the price.
W
Westtnpioneer
Edjumacated
350
603
West Tennessee
Ordered the se45 from google shopping for 302 shipped.
W
Westtnpioneer
Edjumacated
350
603
West Tennessee
Just got home and found the se45. It's packaged well and most of the plastic components have the kfi logo made into them. The winch is black with two stickers on it. It also has some numbers on the front of it engraved. I'm sure one is the serial but not sure on the other unless it's some kind of model number.
W
Westtnpioneer
Edjumacated
350
603
West Tennessee
It is made in China just like 99% of the rest I just hope it was specked out better. I looked at a lot of them online and just bit the bullet and got this one.
41,749
Yep. Someone even mentioned that Warn is from China.
I'm seriously thinking of one of these...
http://www.harborfreight.com/5000-lb-el ... 68144.html
Image 22135
$219, but can be had for well under $200 with a sale.
http://www.amazon.com/Champion-Power-Eq ... B002Q24PBU
815w2BSIzXgL SL1500
$137 from Amazon.
Before you start laughing, check out the reviews for them. Very good!
BigRiver
BigRiver
324
79
It appears to mount atop the bumper tubes. As bigc had mentioned, on a heavy pull, the tension on the tubes may be excessive. I had originally designed a mount like these, but had scraped that idea and gone to a design that attaches to the vertical round tubes behind the bumper.
Would like to see your review on this mount once you have it ready to go.
I saw a champion at Tractor Supply for a little over $100 on sale but was in a hurry and wasn't sure about the quality. Me thinks I may have missed a good deal.
41,749
+1.
Want pics!
bigc
bigc
421
i agree bigriver i dont think pulling from the bumper tubes will hold up it might fool us but mine has not budged yet and i had pulled it really hard with a snatch block and its solid as a rock
A
Anonymous
Wsa thinking about ordering one of theese as well, In my mind im a little concerned about mounting to the detatchable bumper. Looks easy enough I guess mounting the winch upside down would hurt nothing. How does the factory mount atatch does anyone know. Im leaning towards the superwinch terra 45SR seems like it gets as good as reviews as any as i have seen and can be bought cheaper than most. My last Honda I bought was a 300 4x4 4 wheeler. I have always been a Honda fan was a little surprised about how thin the tubing is on the frame and A arm brackets, looks like you could bend it with channel locks. even the plastic on the bed is thin, I guess thats the way everything is made now days. Just hope the engine and tranny are bullet proof like the old Hondas. Thanks and God Bless..
G
GulfCoast
47
0
What brands/models of winches have folks installed on their Pioneers? I assume any 3K-4K winch will fit with the right bracket? I don't want to add "length" to my P2 due to trailer size.
TIA!
