LED BULBS
Crash14
11
5
Mississippi
Thinking about installing led bulbs in my 2018 P1000. Good idea or bad? I’m f good, what brand etc. should I get. Thanks guys.
Reactions: ChadD
108,114
Did u try the search up top?
your answer is there. Alot on the subject with brands and pics.
should you do it? It a preference. If you have pods or a lite bar, those LED’s will be like a candle compared to them
Reactions: ChadD
wyldeman
wyldeman
17
38
Fort Wayne, IN
I did this in attempt to get a brighter white light vs the soft white standard headlamp with a yellow tint. I have a 2022 HP 1000-5 EPS and believe it was an H-11, (but will have to check to be sure). I can tell you this, it was a much better option than dumping $$$ into upgrading to the LED lamps from Honda. MUCH brighter, and a cleaner-white color temperature.
Take one of your bulbs out and run to your local automotive parts store. You will be glad you did.
Good luck!
108,114
How you finger?
did u have the Honda LED’s?
I had the the std honda lights and put LED bulbs in them, they were better but still sucked ass, even had the most lumins you could get and still couldnt compare to the honda LED’s when side by side with one. I went with kock off Honda LED’s for 1/2 the price and couldn't be happier. Much brighter than the LED replacement. But nothing compares to a set of LED pods or small
Light bar. They blow any headlight in these things out of the water.
bumperm
bumperm
1,851
6,658
Gardnerville, NV
And a BIG light bar is even better. Just be sure to carry a fire extinguisher in case it starts to cook the foliage.
I really need to get some night shots of this thing:
20211017 112959
Hillbillytnt
Hillbillytnt
523
1,926
Ky
Most leds kill an am/fm signal that’s why I keep my headlights factory incandescent bulls. I have plenty of light bars if I need light but that’s the only downside I see to changing them. Most are Bluetoothing it anyway
bumperm
bumperm
1,851
6,658
Gardnerville, NV
It's not the LEDs that generate RFI (radio frequency interference), rather it's a "switching" power supply that some use to feed the LEDs. This is often evident if the LED spec has a fairly broad input voltage range, rather than something like 12-14 volts DC.
One way to mitigate that RFI is to use ferrite filters on the wiring (they are inexpensive) as close to the offending component as possible. You can use your radio to check and see if the filters are doing the job.
wyldeman
wyldeman
17
38
Fort Wayne, IN
How you finger?
Ah, I read my comment @Remington. No, I was saying it was much brighter than standard and even brighter than my friend's CanAm LED lamps. I use headlights on the property and on the road and light bar on the trail. Not sure what H13 I bought, but they are great.
Reactions: Remington
108,114
Ah, I read my comment @Remington. No, I was saying it was much brighter than standard and even brighter than my friend's CANND HAM LED lamps. I use headlights on the property and on the road and light bar on the trail. Not sure what H13 I bought, but they are great.
Ik that makes more since now! I was like…say what? 😂
oh I fixed it for ya too! ;)
