P1000 Which LED bulbs for 2022 P-1000/5 Forest?
Bandman
Bandman
128
457
Hayden Lake, ID
I ordered a Torchbeam T2 H13/9008 LED bulb kit thinking it was the right part for my model but it doesn’t have a compatible connector. Can anyone tell me which connector/model I need? I have used the search function…
Thanks in advance,
Rayger143
Rayger143
2,765
23,974
Winfield, BC Canada
Thanks in advance,
Bandman
Bandman
128
457
Hayden Lake, ID
Thank you! I’ll wait until they are back in stock…
Bad_bowtie
Bad_bowtie
Huge member
2,490
14,983
East Tennessee
I've got a similar but different issue. I have a set of factory LED headlights for a 21 Talon but of coarse my 22 Talon uses a different plug. Been meaning to contact @Hondasxs to see if he could make some sorta adapter. I imagine thats the same reason the add a light in the club store is listed as 21 and older?
NorthernJoe
NorthernJoe
333
1,279
Northern Ontario
Make sure you get bulbs that are adjustable! In my '22 trail one bulb sit vertical and the other is approximately 25 degrees off vertical. At first I thought I installed the bulb wrong, but on mine the three "grooves" are not the same on both of the Honda lights. I did some searching and found the better LED bulbs have a set screw that allows you to set the vertical position
Jankyeye
Jankyeye
611
2,771
Tampa, Fl.
The ones I posted have a lock ring that lets you adjust position.
Reactions: Rayger143
Bandman
Bandman
128
457
Hayden Lake, ID
Okay, I figured what I did wrong. When I pulled the bulb off the connector I broke it leaving part of the bulb in the connector. I’ll post pictures this afternoon.
Bandman
Bandman
128
457
Hayden Lake, ID
These worked perfect in mine. Does the Forrest have a different connector than the base model?
Torchbeam T2 H13/9008 LED Bulbs... https://www.amazon.com/dp/B07SZMVNC7?tag=sxsweb24-20
That’s what I thought was weird because I used your recommendation on the bulbs and I appreciate your response. I screwed up when I disconnected the connector and left part of the bulb in it.
Bandman
Bandman
128
457
Hayden Lake, ID
This is what I did wrong: when I separated the bulb from the connector this all should have come out in one piece. Instead the part below stuck in the connector preventing the new bulb from going in. I hope this helps other people that are mechanical knuckle heads like me…
1FF0A2BC 9CBF 4496 976E 555A1F2135BD
Rayger143
Rayger143
2,765
23,974
Winfield, BC Canada
You got it figured. That’s what matters.
NorthernJoe
NorthernJoe
333
1,279
Northern Ontario
The exact same thing happened to me. Must be the high quality bulbs from china
