P700 Nice video to install my Gifted Winch! Others have posted, but this "Guy is Good"! Anything from you guys in the know, want to add some suggestion too
63,560
Been a few years since I installed my winch on a 700.
With the battery under the seat, you have a fairly long-distance to go with the main wires to the battery.
You will need to switch the power wires around to make it work.
Meaning the Yellow and Blue will be the battery wires. and Red and Black will be the winch wires.
Don't forget this when putting them on the contactor post... lol.
Mudwing
Mudwing
36,959
306,563
The Mud holes
I mounted my wEnch contactor on the passenger side under the hood. It allowed me to have room to add an accessory fuse block and other electrical components under the hood. 😉 When I mounted the contactor I added a piece of metal behind the plastic and bolted into that to prevent the contactor from pulling the bolts from the plastic.😎
F744DE9D DBD7 4010 8D70 679DD2C26DB4
9935B924 8C10 4F6C B1EB 5D7107ECDA56
Mudwing
Mudwing
36,959
306,563
The Mud holes
This is showing the routing from the wEnch using the black and red leads to the contactor.
81C70684 B64F 4FD5 8594 148707341773
I ran the black wire to the yellow post and ran the red wire to the blue post. Keep track of that. I like to take notes as I work. 😎 E2D0D593 89D0 4863 8A8C A848280D68CD
Mudwing
Mudwing
36,959
306,563
The Mud holes
This is showing a spot that I felt would maybe rub through on the sharp edge of the frame so I added some rubber fuel hose slit along the side to add protection to the wires. I did both red and black. 😉😎
FD98CACE E08C 47EA B2D2 B6367C8DB747
Mudwing
Mudwing
36,959
306,563
The Mud holes
I ran the wires alongside the factory harness. This was the route for all my accessories. Zip tie after you run your wires because you can make sweeping turns so you don’t have to cut the wire and recrimp a terminal on it. 😉😎
7AAA561D 04B3 43B3 ACB5 117445E706BC
Mudwing
Mudwing
36,959
306,563
The Mud holes
This is how I connected to the battery I might’ve needed longer bolts but can’t remember if that was after I added the accessory fuse block. The blue and yellow wires are going to the contactor. 😉😎
EB19C4CC 7F9B 406C A1E9 772D28FEE08B
