Pioneer 700 2/4 Usefull Service Facts
T
TrailTamer
I thought I would put together a list of use full service facts. This will come in handy a lot when wanting to know what kind or how much of something. All are taken from the Honda Pioneer Service Manual.
Can we get this sticky'ed ?
Differential Oil:
Honda recommends a API classification of GL-4 or GL-5, Do not use oils labeled as energy conserving.
- Use Type - HYPOID gear oil
- Viscosity (weight) - SAE 80
- Recommend using Honda shaft drive oil.
- After drain fill the differential with:
---- Front - 22.5 US oz (665 cm3)
---- Rear - 4.7 US oz (140 cm3)
Engine Oil
Honda recommends a API classification of SG or higher, do not use oils labeled as energy conserving or resource conserving.
- Viscosity (weigt) SAE 10W-30. Other approved colder weather areas can use 5W-30, or 0W-30
- JASO T 903 standard - MA
- Suggested oil - Pro Honda GN4 4-stroke oil or Honda 4-stroke oils or and equivalent 4-stroke motorcycle oil.
- After drain and filter change refill with
---- 3.1 US qt (2.9L) of oil
- After drain only refill with
---- 2.9 US qt (2.7L)
- After disassembly refill with
---- 4.3 US qt (4.1L)
Fuel
Honda states that only unleaded fuels can be used in the Pioneer.
- Type - Unleaded
- Octane number - 86 or higher.
- Fuel tank capacity - 7.9 US gal (30L)
Coolant
Honda recommends using only Pro Honda HP coolant. However a equivalent high-quality ethylene glycol antifreeze containing corrosion protection inhibitors specifically recommended for aluminum engines can be sued.
- Capacity - 3.6 US qt (3.4L) of 50/50 solution.
- Solution 50/50, 50% antifreeze 50% distilled water. Do not increase this for cold weather areas as it will only decrease the cooling performance.
- Fill reserve tank to between Min and Max level.
Spark Plug
- Standard spark plug - BKR5E-11 (NGK) or K16PR-U11 (DENSO)
- Gap - 0.039-0.043 in (1.00-1.10mm)
Brake Fluid
- Honda DOT 4 brake fluid or equivalent DOT 4
Tires
- Front 10 psi (70 kPa) MAX
- Rear 12 psi (80 kPa) to 18 psi (120 kPa) MAX
Battery
- USA YTx14-bs 12v-12 ah (10HR)
- Canada GYZ16H 12V-16 Ah (10HR)
If you have any other use full information please leave it below.
admin
admin
Your club! I just turn it on!
317
Re: Pioneer Usefull Service Facts
You are right, this will be useful...
But we got to get our Pioneer's first. Thanks I will sticky it.
Reactions: Junkymac
justottie
6
North Idaho
Rear Differential Capacity
Hi TrailTamer - is that true? Rear diff capacity is only a little over 1/2 cup? Do you think that's a typo in the manual? Thanks
T
TrailTamer
You mean as its too much or to little?
I think the front is actually alot.
My foreman takes less then 3 oz in the rear.
If you are comparing to the Big Red diff... remember the diff in the Pioneer is back to the normal closed diff vs the open diff the Big Red had.
atvsnowman
atvsnowman
23
What you talking about... open diff and closed diff. 3oz is not much.
BigRiver
BigRiver
324
79
The rear diff on my Rubicon takes very little gear oil, so I wouldn't be surprised that the Pioneer would be the same. My front diff will take more though.
Swamper
140
15
I changed my rear axle gear oil and went with Royal Purple synthetic gear max 75w140 hoping to tame down the gear whine a bit. It helped a little but nothing drastic. I think some gear noise is coming from the tranny but I'll definitely stick to honda oil for the engine/tranny.
barefootwelder
11
thanks for all the info, will print and keep handy.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
How often does everyone change their spark plug? I didn't see that in the manual but maybe I need to look harder.
63,392
This came
in handy for me today..
Just finished a oil change and water pump replacement... Details soon.
63,392
Weep hole started leaking. Replacement was a total B. Been trying to do a short write-up but haven't got around to it. Pictures in my gallery.
I now think having the weep hole tube is important. In theory, it could hold a air pocket and prevent sand/water from entering. Not sure mine even had a tube! I recommend adding one.
Reactions: Deluxe700
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
That sucks. Hopefully this isn't common. If you do a write up I'd like to know where you install the tube on the weep hole
JimmyA
JimmyA
1,644
5,503
Northeast texas
Differential Oil:
Engine Oil
Fuel
- Type - Unleaded
Coolant
Spark Plug
Brake Fluid
Tires
Battery
Good info, Thanks!
N8theGR8
N8theGR8
74
Central Texas
This came
Do you use any different gear oil other than the recommend 80w-90? Other threads say they use 75W-140 with some Lucas oil stabilizer to help quite the gear noise. Thoughts?
N8theGR8
N8theGR8
74
Central Texas
Differential Oil:
Engine Oil
Fuel
- Type - Unleaded
Coolant
Spark Plug
Brake Fluid
Tires
Battery
Any transmission oil maintenance?
F
Fishi812
7
IL
Today at 4:43 AM
So is the revving idle normal I am looking to get a 2019 700-4 and it revs when idling in neutral. When you put in drive it run fine no revving HELP
