P700 Pioneer 700 with Can-Am Commander Shocks
scott
scott
1,212
1,354
lyman, South Carolina
is anyone just doing the front shocks with commander shocks, or does the lift the front too much. I dont want to lift the rear any, i can barley fit in the shed as it is
Yes, just doing the front is fine. A lot just do the front swap.
Reactions: Dragon21
Ems-Cam
Ems-Cam
252
336
Alberta
I did both. I needed the better ride all the way around, but then height is not an issue here.
Reactions: CumminsPusher
eastenn
eastenn
220
469
Bristol TN
www.fb.com
Just do like me, lift it too high for your garage and make it too wide for your trailer.. then spend more money trying to fix your new problems :rolleyes:
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Just got front shocks from a 2012 commander 1000 from eBay. Been keeping an eye out. Wish they were red rather than yellow, will probably get covers for them
7,149
27,222
You will not be disappointed!!
G
gokorn1
41
20
So i've been trying to follow this thread and just want to clarify some things before I start searching for a st.
I plan on just doing the front shocks. So they should be a direct bolt on with no bushing mods required?
What 2011-14 Commander Model years willl fit?
Ems-Cam
Ems-Cam
252
336
Alberta
You will need to change out the rear bushing and add a larger sleeve as the rear bolts are larger than the stock. The link for the bushings is all in the first few pages.
Fronts are a direct bolt on.
7,149
27,222
You are correct, the fronts are direct swap. Commander XT's 800 and 1000.
Sent from my GT-N5110 using Tapatalk
G
gokorn1
41
20
Thanks, It was alot of posts and a little hard to follow while at work.
7,149
27,222
Just FYI , it is going to give you a couple inchs of lift when set at lowest adjustments. If you get a good deal i would get all 4 and then swap rears later. It is an unbelievable difference in ride quality.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
I wish i could have bought the rear, but i cant put them on which sucks. I believe with the commander shocks in the front, you put those at the softest setting and the rear at the highest?
Im gonna have to put the pionner in the door opening and see how much i can bring it up (if any) without hitting the roof
tjoreo
tjoreo
1,011
1,929
Southern Idaho
Just keep an eye on the used ones. I bought a used set and the shock absorbers were no good. They're sitting on my shelf until I can buy some new ones. But even the price that I paid for them, it saved me quite abit for just the springs and retainers then to start from scratch.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
that part does make me nervous, I wont get rid of my stock ones because of that. But $200, and the ebay place i got them from seemed to have good reviews
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Finally had a good trip to try them out. They were great. Highly recommend doing the upgrade. Keep an eye on ebay.
IMG 6587
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
How are your tires wearing? Comments? Complaints?
very pleased with them... still not my favorites in the looks department, but traction and ride is great. I got a flat this last ride when my valve stem came out. had to ride back on a completely flat tire. to make it worse i had a broken rear axle so i had to stay in 4wd. got the tire reinstalled today and to my surprise no damage noticed as of now. the tires have exceeded my expectations for sure.
IMG 01231
G
gokorn1
41
20
Will shocks off a Commander 800R fit or does it have to be the 1000
