BOX1 - TEST
Prntdckt's 2022 Talon X4 Build
Scoop
Scoop
4,215
15,756
  3. Talon R LV
Thanks, @Prntckt. As you already know, I will likely be stealing this design for my machine. :cool:
test - test -test
Prntckt
Prntckt
1,049
7,225
Altoona, WI
No problem. Most all of the modifications and accessories I have implemented on my Pioneer and now on my Talon were ideas I read about in this forum. The knowledge I have gained from the other member's posts has been extremely useful and valuable.
test - test -test
Prntckt
Prntckt
1,049
7,225
Altoona, WI
Installed a weatherproof SAE connector on my fender above the OEM battery for connecting my trickle charger
20230803 185415
20230803 185451
test - test -test
Prntckt
Prntckt
1,049
7,225
Altoona, WI
The OEM tender springs were collapsed and coil bound both on the front and rear of my rig.
Facebook creation 69915276
Too many accessories I guess.
Purchased a set of dual rate springs from Shock Therapy for the Talon.
After unsuccessfully or unsafely trying to compress my springs with ratchet straps, and a couple varieties of spring compressors, I purchased a Strut Tech spring compressor. So much easier and safer
Facebook creation 69926193
The packaging of the strut compressor allowed the parts to roll around inside the box during shipping, fortunately no damage.
The assembled unit makes spring changing safe and easy.
Expensive, but worthwhile.
Fits right in with the Talon accesory budget!
Facebook creation 69904100
Thanks for the recommendation @Tramguage1 .
There is quite a difference between the OEM springs and the Shock Therapy springs
Facebook creation 73133601
The new springs restored my ground clearance and suspension travel.
The ride has improved a lot!
20230823 200505
20230823 200525
test - test -test
Prntckt
Prntckt
1,049
7,225
Altoona, WI
I have had intermittent problems with the EPS tripping out since putting on the 30" Terrabytes and the Tusk Uinta wheels.
I watched the video by @TerryH of the SuperATV 400 watt EPS and decided to give it a shot.
The kit arrived nicely packaged
Facebook creation 72215135
Quite a difference in motor size.
Facebook creation 72224993
It's a tight fit, especially because I installed my winch controller, battery isolator and aux relay in that area.
Had to modify it slightly to get it to fit
Facebook creation 72238660
Terry's installation video was a big help and saved me a lot of time and trouble. Thanks a lot Terry!
The new EPS unit made a huge difference.
Steering movement is effortless even on pavement
test - test -test
Coeus
Coeus
Major General
58,517
586,351
Signal Mountain, TN
  2. Talon R4 LV
I tried disconnecting the sway bar links as some in this forum have suggested, and liked the improved ride at slower speeds. I decided to install the Speedway shocks that other forum members have used so I didn't need to worry as much about body roll at higher speeds. They have worked out well.
Any reason you installed them upside down? Seems like they might rub on the springs if you did, but hard to tell
test - test -test
Coeus
Coeus
Major General
58,517
586,351
Signal Mountain, TN
  2. Talon R4 LV
What’s the length of the sway bar from bend to where the shock is attached?
test - test -test
5,023
22,429
For the record, on a 2 R -
If the swaybar had square corners, the short arms are 11" long. The straight ends themselves are 9" long.
Reactions: Coeus
test - test -test test - test -test
Prntckt
Prntckt
1,049
7,225
Altoona, WI
Really no reason. I oriented them as the Fox Shocks were oriented. After roughly 5000 miles of use they are working fine.
They do not rub on the springs
Reactions: Coeus
Coeus
Coeus
Major General
58,517
586,351
Signal Mountain, TN
  2. Talon R4 LV
Thanks! I found out that the X away bar is about 2 inches shorter than the R…. So doesn’t seem like they will work on an R
Reactions: JenElio
test - test -test
5,023
22,429
The arms are 2" shorter or shorter across the width?
test - test -test
Coeus
Coeus
Major General
58,517
586,351
Signal Mountain, TN
  2. Talon R4 LV
Based on your measurements, the X is 9” if the sway bar had square corners and 7” respectively…
Here’s a pic of the X that @906UP took for me:
IMG 6081
Reactions: 906UP and CID
test - test -test
BOX2
box3 - TEST
