P500 Rotella T6 oil
OlYeller15
OlYeller15
192
1,170
Finally got around to changing the oil today. After a short test ride WOW what a difference.Engine seems quiter but the gears and shifting is Much better. If you’re on the fence about trying it out get off and get it done. Hope this helps out… LET THE GOOD TIMES ROLL!!!
JCart
JCart
897
2,024
Kamloops, BC Canada.
Tried it in my 2015 P500… mmm switched back to Honda Semi Synthetic. Mine just didn’t shift as nice. Once back to Honda stuff it’d snick into gear beautifully, maybe I shoulda messed with clutch adjustment more… oh well. Now not runnin down T6 as I use it in my 7.3 powerstroke and other Honda products, outboards, Generators, water pumps etc., is good stuff for sure! Glad it’s working for those that it does…. Makes life easier too if you’ve got a bunch o’ gear and only need 1 brand.
j
42,121
See...we've been trying to tell you...
  • Haha
Reactions: CID and Buggyman
G
GolfCart
125
382
NH
Are you guys running T6 in the engine and sub-transmission? What weight?
This would be for a 2020 P1000-5
107,956
Yes, and its rated for wet clutch
107,956
Shut the front door!
Are u second guessing now?
I was searching the MANY threads on your question to help u and came across this!
Post#22 🧐
  • Haha
Mudwisel
Mudwisel
7,095
62,322
Tampa Bay Florida
I run Rotella in everything I can. Race bikes when I raced and lawn mower too
Reactions: Remington
G
GolfCart
125
382
NH
Post#22 🧐
No not second guessing, I was just not sure where to use it and what weight.
Yeah, that was my intent to use back then. I use T6 in all my other toys but ended up using GL4 for the Pioneer.
I use the diesel rated T6 15w40 in my motorcycles because it doesn't cause slippage with wet clutches.
I am due for another oil change, so I searched and found the T6 thread and found that is ok to use, which led to my question is it ok to use in both engine and transmission.
Then I asked what weight to use in both cases.
107,956
Okie dokie!
Use the 5-40 T6 in your Honda sxs
I use it in my truck, my P1 since 16’, my old P5 and my currant Talon.
G
GolfCart
125
382
NH
Okie dokie!
Thank you, just to confirm you use 5-40 T6 in both the engine and sub-trans?
107,956
Yup. The DCT u want to use 10-30 with moly preferably. Im sure some will have other opinions. I go by the book of @snuffnwhisky only he likes Amsoil
5,078
22,821
Not true, Remi.
The DCT and engine share the same oil and so do our wet clutches, the last place you want to use moly additives. The sub trans gets the moly, not the DCT. :cool:
  • Haha
Reactions: PJon and Remington
107,956
Not true, Remi.
Ahh Fuc! I thought I had it Ass Backwards!
If im lm looking at it I know what one is which 🤷🏻‍♂️🤦🏻‍♂️
Reactions: CID
