P1000 SATV tilt up windshield FYI
rudyeng
109
554
Florida
Hey guys I wanted to share a simple fix to a problem I had with my SATV windshield. The bolts on the top pivot bracket came off.. Sounds insignificant but when you factor in the 95 degree heat wave and field retrofit it was a PITA.
Solution:
Remove all of the SATV provided M6 bolts and install the same but longer. That gives you more thread to work with. I then used lock tight and 5200 Sealant on the thread.
Best of luck !
Rudy
IMG 20220901 134841559 HDR
IMG 20220901 134836238 HDR
russknight
russknight
1,910
7,506
Perry Florida
The only screws I've had any issue with loosening are the two screws that attach the windshield mounting brackets to the top of the roll cage. I Loctited them and haven't had any more issues.
