P500 School me on spacers
Chooglin
No need to be concerned, Trigger's OCD is flaring up :p
The wheel offset from Honda is different from front to back so if you run aftermarket wheels with the same offset on all 4 the rear tires will set a 1/2" in on each side as compared to the front. If you have stock wheels the track is the same.
This all sums it up right here.
Most will change the wheels when buying new tires. So width only changes when you go to after market wheels that are all the same width.
Reactions: crewcabrob
T
The_Frontiersmn
15
23
Minnesota
Why? I just mounted a plough and have never had any experience with one.. Should uneven track width be a concern?
I know it's an old thread, but I don't think your front and rear track being different widths should affect pushing a snow plow too much. Where it does make a difference is driving through snow of any depth, as your rear tires have to make at least a partial track on their own rather than following down the tracks of the front wheels.
C2Corvette1
C2Corvette1
92
434
53
Texas
I did not see it mentioned, but are our wheels (and if so then hopefully aftermarket wheels) "hubcentric" ? It looks like the Moose spacers may be machined correctly for that with a centering hub counterbore and then a lip on the wheel side, but others I see are just flat both sides.
crewcabrob
crewcabrob
1,029
4,038
Omaha
I know hub-centric is the best way to make sure your wheel sits correctly on your hub, but I can tell you that at 39mph with offroad tires, you may not notice if they aren't perfectly centered. If the P500/520 could travel at higher speeds, I would be more concerned about it.
Rob
157,135
Rob
I think it's more about weight distribution. You don't want the full weight of the vehicle resting solely on the lugs.
lee
lee
Village Idiot
2,339
13,132
Springfield Ohio
No.
honda centers the wheel off the lugs and the lug nut seats are spherical.
Hub centering always has some offset due to the clearance required for assembly.
But, as @crewcabrob said dose it matter with off road tires at low speeds?
