P1000 Shifting Problems
E
elkmoose
wyoming
  1. 1000 6 Crew
I purchased the Honda 1000-6 and I have some concern about how it is shifting from 2w drive to turf and from 4w drive to 4w drive dif lock. In most cases it will not shift unless I move some and sometimes it takes quite a while before it shifts. It is not always the same. And how fast can you go to try and get it to shift before you tear something up? Is it suppose to shift without moving? I guess Im trying to find out what is acceptable shifting. Thanks
107,836
Welcome from once great Michigan
We need some info first before we can proceed.
What year, model, miles is your rig?
We also require pics of it to make sure your not a Poo Poo (Polaris) Infiltrator.
As we say...Pics Or It Didn't Happen!
As for your issue, depending on the rig, ALWAYS check our search up top first. There's tons of info in there that I'm sure will fix this issue, cable adjustment and rear diff adjustment.
ODAMO
ODAMO
1,177
3,206
On the 22s and 23s the the rear diff lock cable at the rear diff needs to be adjusted per the manual.
I can say that it goes into and out of a little easier with time. And keep in mind that it will vary in engagement depending on circumstances.
I always try to anticipate when I will need to shift and do so when there is no driveline bind and wheels straight
Mark in Northern Iowa
466
2,082
Floyd County, Iowa
kramnella.wixsite.com
It tells you how to do it in the manual. You have to turn side to side.
Read this post in another thread, it has a good example.
Have a good day
PJon
PJon
780
3,150
Arizona
I’ve found that on my 2018 P1k5 that I only have to be completely stopped is when changing between high and low. The other changes work fine when under 5-10 mph as long as nothing is in a bind, ie; turning, any type of loading or unloading of the drive train. Even if stopped and trying to go from 4high to 2 high or turf it my take up to 10 to 15 ft.without bind to actually shift.
