Tablet, GPS and MAPS setup for my P5
KyGal83
KyGal83
7,846
78,495
Kentucky
I want to start venturing out more with my P5. Looking for advice on a navigation setup for it. Starting completely from scratch here. I know many of you have tablets and use maps. I looked at a couple of setups at TO.
Do you care to share your setups? Offer advice on a tablet, apps, maps, mounts for inside the P5. Everything I currently own is Apple based. This will be used exclusively for riding so not opposed to Android for this. I am not a complete novice.. I have been using Garmin Explore for Jeep navigation wheeling on trails & county roads and mapping some on a local lake. I like that I do not need cell service to run it. Can anyone offer some advice?
@lee @The Green Goat @TripleB @JACKAL @Hondasxs @Tramguage1 ANYONE?
(@Remington .. Already did a search. Read that info. Looking for more. ;))
JenElio
JenElio
65,906
614,477
Loxahatchee, florida
@NTCPrezJB will make you a great deal on a tablet already set up....👍
57,290
I use lifetime maps but knowing what I know now, I would just buy a tablet and down load the maps off of tackett creek mafia. Mike smiddy has about everything you would want for TN/KY.
He's got it built out for Backcountry Navigator now too. I use Orux since that was what I learned on with his maps, but it is nice to have a backup.
@KyGal83 I have used this Samsung in my Talon for the last couple years with no issues. I like the smaller tablet in the Talon since it is mounted to the grab handle. I use a 10.5" tablet in the P1k5 since it is mounted up on the rollbar and there's more space. Good price right now for Prime Day too if you've got Prime:
I use these for both tablets (one linked is for the smaller one):
TripleB
TripleB
11,991
102,013
Caryville, Tennessee
Sweet deal. Definitely the way to go IMO.
KyGal83
KyGal83
7,846
78,495
Kentucky
Thanks.. I am following the Tackett Creek Mafia also... I will see about his downloads.
KyGal83
KyGal83
7,846
78,495
Kentucky
Thanks!! That is a great deal... I assume the memory on this can be expanded with an SD card, any idea?
57,290
It can. Android 12 introduced some new security garbage that prevents you from accessing the regular filepaths these apps have used forever to store data. There is another app you download that restores that access. I believe it's listed on the TCM page as well. I'll have to go get mine out and charge it then I can add that app name.
Vondy
Vondy
1,416
9,187
Houston,OH
I had one in my P500 and now in my Talon. I started with it mounted on the dash and could never see it very good due to sun so I moved to above. Then it had too much movement so I modified it to use two ram mounts and now it doesnt move at all.
Started with an Ram X-grip and then switched to the one below. Its the same that lifetime sells, just cheaper
Used two of these to the rollbar in the talon.
5,099
22,928
I started with GAIA on an iPad, its base level is a free download and Apple, Android and Windows compatible. I can see my tracks on any device once logged in (don't need internet to use it though). A friend is using Avenza and I wanted to be bilingual but I can't even get a map to show up so I gave up on that. I might have to download a map to use it but GAIA auto loads its topo when I open the app - a good thing for this #oleguy computer phobe. :cool:
The most important feature of any GPS app for me (and why I gave up on dedicated units like Garmin) is that GAIA stores my track logs permanently and doesn't seem to have any capacity limits. A dedicated GPS unit only stores a few days of tracks then they have to be uploaded to your computer if you want to keep them. That won't work for me because I go back to areas and want to ride trails I missed last time and need to know where I've already ridden (without having to download those old track logs before I leave home).
My favorite iPad screen shot, 1500 miles of southern Utah over 3 weeks - :) This would have been really difficult without tracking.
I bLPBMRn X2
What an area looks like before it’s ‘tracked’.
1689179549953
The Green Goat
The Green Goat
1,812
12,976
On a more serious note, I use pretty much this exact setup.
As has already been said, TCM has a fantastic free trail overlay for TN/KY that you can use (I run Orux maps for this). If that's all you plan on riding, I'd go that route to save on LifeTime Trail Maps. If you plan on venturing out into other states, LTM is also pretty good and is the same GUI as Orux so the transition is seamless.
I use the Samsung A7 as above in an OtterBox case. Its not 100% waterproof, but its pretty resistant.
I also use the RAM mount Adam posted on a medium arm, and have that mounted to the upper dash. It's not nearly as rigid as I would like and tends to flop around over bumps. I have on my To-Do list to stiffen it up somehow (doesn't every man?), but it works for now.
I also have a USB and cigarette plug wired inside of my GoochBox so the tablet can charge while riding. I run a short charging cable out of the box, and then close it up tight for waterproofing.
57,290
My tab-tite sits on the edge of the grab handle, so that prevents it from going flaccid on me. I think I'll be switching.... God help me here... to the bigger RAM balls @Hometeam runs. His tablet doesn't move around anywhere near as much as mine.
Scoop
Scoop
4,290
16,098
  3. Talon R LV
My Samsung Tab A7 10.4" (not the A7 Lite, but the A7) is mounted to the ROPS above my head using the following RAM Mounts parts (all for 1" 'B' ball ): Strap hose clamp mounted on ROPS, short arm, round plate attached to the backside of a Tab-Tite Holder for 9"-10.5" tablets w/heavy duty cases. The case I use on the tablet (it fits in that RAM tablet mount with this heavy-duty case on it) is the SUPCASE Unicorn Beetle Pro Series Case for Galaxy Tab A7 10.4" tablet (2020 release)).
Pics from my install in my build thread are in this post here, including running a dual USB 3.0 charge port to the back of the tablet case so is was always at 100%.
I actually have 4 or 5 different GPS programs installed and use several of them.
For Michigan trails, I use Orux (free version, not paid) with the maps from vvmapping.com (he is Michigan based). $40 one time.
For TN, I did pop for Lifetime Trail Maps, but vvmapping also has trail maps for KY, OH, TN, VA, SC and NC all for $40 one time.
I have onX Offroad, Gaia GPS, and a few others installed, but haven't used them much.
I love the non-proprietary nature of buying good tablet with a good GPS chip (translation: Samsung) and being able install and try out all the different GPS programs you want until you find what suits you best.
Hometeam
Hometeam
954
3,835
Normal, IL
I’m sorry could you repeat that?? Did you say something like ‘Hometeam was RIGHT and you want to have bigger balls like Hometeam has”?? And then you threw some gay shizle in about Raming. I’m confused and a little offended!!😆🤣😂
KyGal83
KyGal83
7,846
78,495
Kentucky
Ummm… @Adam490 …. What are you and @Hometeam doing in the woods with these “mounts”? 🤔 Is this something @TripleB suggested?
IMG 2430
906UP
906UP
13,205
123,487
da Yoop
Samsung Tab A....something or other. About 8" screen, Orux app using VVMapping. For your area VV is OK but there's better options available
