P500 Voltmeter install.
HiFive
HiFive
625
2,545
West Central Fl.
I've installed a voltmeter but not in place of the cig lighter port, just added it on the dash
I've installed a voltmeter but not in place of the cig lighter port, just added it on the dash.
I was thinking of using the power port because there is not much room on the dash and I can use the wiring that's already in place .
HiFive
HiFive
625
2,545
West Central Fl.
Yeah! Bought one on amazon and it seems to work OK, good for a quick check on battery charging while engine is running plus
the usb outlet comes in handy!
Did you use the power port location for the install? I what to use existing wiring.
11,366
84,700
Then suggest the OEM sub-harness, use one of the 4 hot leads. Installed my voltmenter in the upper dash, between display and glove box.
Some examples
HiFive
HiFive
625
2,545
West Central Fl.
My quick voltmeter/ usb installation. Easy solution and can use the original rubber cover on the power point. $10 part.....
IMG 20220130 154957 hdr IMG 20220130 152449 hdr IMG 20220130 152307 IMG 20220130 154946 IMG 20220130 154951 hdr IMG 20220130 152948 hdr IMG 20220130 152752 hdr IMG 20220130 152847 hdr IMG 20220130 152439 hdr
Scoop
Scoop
4,251
15,928
  3. Talon R LV
That'll work in a single battery setup, of course, but not a dual battery setup.
Scoop
Scoop
4,251
15,928
  3. Talon R LV
Will work with an isolator setup as well but only voltage on one of them.
Which is exactly what I was implying. Sorry if I confused anyone by not specifically stating that. 😜
159,194
You just have to remember you're in the 500 threads. Isolators, burnt clutches, bilge fans, ECU relearns, not fitting through gates... none of that really applies over here.
Scoop
Scoop
4,251
15,928
  3. Talon R LV
Understood and thanks.
Do folks not run any type of dual battery and isolator setup in the 500s? Or do they not really need them?
