P700 What I have found...
I
Ipokebadgers
Central CA
I'm sure those of you that have been owners longer than I have seen all of this, but here are a few things I have found on my new 2021 700 Deluxe.
I have been checking for loose bolts and just looking at everything trying to learn what I can about the lay-out of my machine. I found both battery terminals to be only finger tight. I now that could have caused some issues. I was looking at the door hinges and noticed on of the top bolts on the passenger side was not flush. I got the appropriate 6mm hex head wrench expecting to tighten the bolt and found it wouldn't move. I tried backing it out and it moved a couple of turns and stopped. It is obviously cross threaded. It it had the paint pen markings so who ever checked it either didn't notice it or didn't care. One lug nut on the driver side rear wheel was loose. I found a plastic push rivet lying under the seat on the rubber cover. I still haven't found where it came from. and I have had two of those plastic push rivets fall out on the dash while driving. They were not seated firmly enough.
This isn't a complaint, just observations. I worked in a job where looking for loose fasteners was a part of the job. I would like to think this type of thing wasn't the norm, but I'm old and know better.
I have spent a couple of days moving limbs and cleaning up the property and love this thing. My four year old granddaughter loves it too. Her dad has a polaris...
42,130
It's becoming more the norm. My 2020 had noticably worse build quality than my 2014 did...and it wasn't exactly the gold standard to start with. I used to buy Hondas to get away from this sort of thing. Now I know that if I buy a Honda, I will have to deal with it. At least in the SxS's.
You might want to check the hose clamps, esp around the water pump.
Backwoods
Backwoods
32,755
335,843
Douglasville ga
I was very fortunate Southern Honda power sports did a thorough job on prep on both pioneers I have bought from them. I've never had any of the issues common in the forum. I consider myself lucky and appreciate my their work. I got tired of waiting for them to prep it but they were thorough and was able to watch.
Farmer
Farmer
2,850
16,380
Southern MO
Yep, wish we could blame it on the temp workers in South Carolina but like @DG Rider said.... this stuff has been going on since 2014. Welcome to the future of our society. Don't sweat it though.....At least you didn't go Polaris!!! 😂 😂 😂 😂 😂 😂
KevP700-4
KevP700-4
249
609
Northern MI
Ours delivered in May '21 was a pretty good build. All was tight and we've had no warranty issues. One thing i would advise on though is before you drive your new machine beside checking all the bolts you can reach is to charge your battery before that first ride. When we took delivery I put the new 700-4 in the barn to check it out and thought why not put a charger on the battery. Well, it took 6 hrs. to top off the battery. Now the battery has performed very well since and yes the battery may?? have topped itself off with the alternator on a long break in ride, but I think I was better off topping it with a charger before that first ride. Not real sure how the electronics, engine control or dash instruments, would handle minimum voltage. Anyway all's good with the 700-4.
Glock21user
Glock21user
" Nothing succeeds like excess "
1,815
9,039
Livingston county, Mi.
Many of us have had that issue myself included.
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
yeah i found a few things on my 14 700-4. like push rivets not right and a bolt here and there that may have been torqued but i didnt think it was. the one thing i do everytime i get a machine new or used is i tear it down all the plastics , plugs and such and check everything. i dielectic grease all the plugs. check all the bolts. i think mine was just pop rivets and 1 plug wasnt snapped all the way. other than that i turned a few bolts about an 1/8th of a turn. now my new cfmoto. when it did its ear down i found quite a few things plugs not clipped and bolts not torqued. fuses not all the way in place.
Reactions: Glock21user
livefromthetree
livefromthetree
It was a damn good ride. Seriously good.
466
1,309
Mount Vernon Indiana
What CFMoto did you get?
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
the 800 xc 4 wheeler. couple things i had to do to it to make it submarine ready but all in all its like if honda made a v twin belted machine lol.
Reactions: livefromthetree
livefromthetree
livefromthetree
466
1,309
Thanks. Maybe I did see where you mentioned this on the FB group too. Was hoping someone had picked up one of the CFMoto SxSs with some feedback. I know they are cheaper, but they look like fairly well built machines
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
iv been reading up on them i believe 5he 800 and below sxs have a internal clutch pack as well m not sure what models but i know the 800uforce and zforce does. my next wil be a 800 zforce ir the 950.
Jerryg
Jerryg
10,943
88,163
NEPA
I can guarantee you, stuff still built in Japan don't have these issues.
It's a shame they can't recreate that quality here in the states.
