P700m4 Winch has no pull power
Jayrock
7
9
I mounted the Honda (warn ) winch, wired it up, checked in out runs fine but will not pull the SXS on level ground. Found the winch pulls the voltage way down in the 5-6 volt range?
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
is your machine running while you are doing that ???
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
they draw insane amount of amps while underload where the stock battery has no hope to power it it need to be running
Reactions: Jayrock
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
try it again in neutral running and give it a little bit of gas
hobbes
16
12
I have the same winch. You have to keep on the gas to get the power out of it and then it is still hard on the factory battery. I used mine to pull myself out of 8 inches of mud and water up to seat a few weekends ago. Personally I am looking at going with a regular battery to help handle to load a bit better.
Reactions: Buryit and Jayrock
I killed my factory battery winching, WITH the engine running.
They draw upwards of 300amps when they're really pulling. So around 3500-4000 watts
Reactions: jak9922
Jayrock
7
9
I figured it out! I had a bad connection on one of the crimp ends on a negative cable. Now she pulls like a 3500# should.. Thanks guys.
Reactions: Hondasxs
Jayrock
7
9
Thanks guys, I figured it out. I had a bad connection on a crimp end of the negative cable making for a poor connection. Thx
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
Welcome to the Club @Jayrock !! glad to here you found the problem!
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
That was going to be my next suggestion lol coming from your friendly neighborhood electrician and yes i did just make a spiderman pun :p
Lynn
Lynn
263
134
Yakima,WA
What's the winch rated for? all winches are rated with only 1 wrap of line on the drum and so with every wrap of line you lose a huge amount of pulling power. Bigger winch ? or get some snatch blocks and double or triple your line. I know it's a pain but at least you can pull yourself out.
