P700m4 Winch killing radio
N
Norndorf
12
12
Central PA
So just added a new Kfi plow and hydraulic control. Everything works fine but now when lifting the plow with the winch my radio shuts off so I’m assuming the winch is demanding to much power. I’ve got all my accessories wired to a secondary battery, should I maybe separate the winch back to the original battery and leave everything else on the secondary?? Need some help because I’d like to listen to some tunes while out plowing!!
Reactions: TripleB
NewHere2
NewHere2
Village Idiot In Training
35,636
303,388
High Plains of SD
Have you considered shortening the tow/lift cable length on your winch. The winch develops the most torque on the first wrap around the drum. The 20 year old rig we use around here for plowing only has 6'-8' of cable on it. Works much better. Might help to extend your battery life.
Reactions: Mudder
N
Norndorf
12
12
Central PA
I’m not worried so much with battery life but with power supply. I’m thinking it’s just not got enough juice to run both when that winch initially kicks the system. Plus this is my rig to go riding on too so I don’t want to swap out different length winch ropes if I don’t have too.
Reactions: Mudder
N
Norndorf
12
12
Central PA
Confirm, the winch is direct to the battery and not connected to a bus bar, relay, or anything like that? Both Hot and Ground?
It’s going to my bus bar coming off the secondary battery which all the accessories including the radio is also. So should I connect direct to the secondary or primary battery with just the winch?
Reactions: Mudder and Mudwing
Vikes79
Vikes79
SKOL!
10,877
105,537
South Dakota
  2. Talon X4 LV
Yes you need to run the winch leads directly to the battery.
Does the radio just die on the bump of the winch? Or when running constantly?
I have a blink of my led lights when I bump my winch, but I don’t have a radio ( i use a bt speaker). I’m most likely going to install a capacitor and diode on my big led bar to eliminate the blinks when I bump the winch. My winch is wired directly to the aux battery with everything thing else on a bus bar on the same battery on my P1k5.
NewHere2
NewHere2
35,636
303,388
High Plains of SD
Best to run those winch cables from the contactor to the second battery. Using the same heavy gauge wire that came with the winch.
N
Norndorf
12
12
Central PA
It dies on the first bump of the winch. Where do I run the lead for the switch though? I’m confused because if it’s all from the secondary battery isn’t it all pulling the same regardless if it’s directly connected or through the bus bar?
Reactions: Mudder
N
Norndorf
12
12
Central PA
Heading to pick up cables now. But what’s the difference if I have them direct connected vs through the bus bar if they are all tied to the second battery anyway? Also, hot lead to the rocker switch coming right from the winch solenoid too?
Reactions: Mudder
NewHere2
NewHere2
35,636
303,388
High Plains of SD
Without knowing what the winch manufacturer recommends for wire size or installation techniques, my guess is you are just starving the winch of available amperage. So its pulling all the available amperage from your buss bar, causing the rest of the accessories to malfunction.
If the battery is properly sized for your working load and in good working order, it should handle all the load of the winch and various accessories. Provided each accessory receives enough amperage to make it work properly. So what limits available amperage ?? Generally the size of the wire being used and the quality of the wire.
If the size of the wire going to your buss bar is smaller than the size that came with the winch, it can be a problem. Then throw on the rest of the accessories and the problem gets worse.
In addition, your ground wire should be of equal or one size larger than the power wire. It just works better. I like to use a circuit breaker (or fuse) rated for the stall/maximum pull load of the winch on the main power wire. My 2500 Warn winch requires an 80 Amp. I like to mount them as close to the battery as possible just for safety.
The power feed wire for the rocker switch should work off the buss bar, once you connect the main winch power wire to the battery.
Hope other more knowledgeable folks will "chime in".
Mudder
Mudder
NTC Ambassador of Walls
11,316
84,076
I had a radio drop off on current swing. Many radio owners manuals list the specs +/- voltage. My issue was intermittent high voltage spike due to a bad voltage regulator at 18 volts. You could have the opposite swing. On an atv plow set up, I used a pulley to reduce speed and lifting load because of the # of full cable wraps on the drum.
Vikes79
Vikes79
SKOL!
10,877
105,537
South Dakota
  2. Talon X4 LV
I got a similar phenomenon which I only noticed when I put my big light bar on. I can see on my dual volt meter that my voltage on my buss bar plummets like a rock when I bump my winch. I suspect the OP has the same problem.
