P1000m5 Wonky receiver hitch
Dchilds75080
40
65
Richardson, TX
When I bought my new-to-me 2016 Pioneer 1000-5, I was told the only real “issue” the seller knew of was that the receiver hitch was tweaked. Of course, there were several things I considered issues that he did not. That’s beside the point.
At one time there was a rear basket in said receiver that was backed into a tree. I suppose the basket was stronger than the receiver (probably not a good sign) and it gave the receiver a facelift.
I have a welder and some mediocre fabrication skills so it was not a deterrent for me. I spent an evening cutting and grinding off the old, twisted receiver to get it down to the portion of the frame that extends past where the rear a-arms attach. From there, I designed a plan in my head using almost exclusively materials I had laying around my garage. I did have to order a receiver tube. It’s mostly mocked up though I need to adjust some symmetrical issues. It’s not burned in yet. Here is where I am so far:
385b29f16fc2d2b4d79630b692339106
5ba9fc5bccf70459c9227bea5e200e1f
Ace10d2be2d53a88b1bef9506cb5bfdf
This isn’t intended to tow anything of substance but I think it will be quite a bit stronger than OEM. Anyone else had to do this? I think I rear that Honda strengthened the design in the later models.
63,988
Looks good.
The 2016 models could only handle 200 lbs of upward force and it would rip off. If you left the hitch in and went rock crawling you would push it up in no time.
Forced a redesign for 17+ models.
Dchilds75080
40
65
Richardson, TX
I couldn’t get the extra vertical pieces to work out because of the angle of the frame. I still think this will be plenty strong.
4c8021304457f17baa5a50e4cd08af177d679cf8f0b69154b9a3048cbb8dc37bD8ac0258107dedd005c8d0bbf8321cbf6263c8fc89cbee43bc500925bc2f9dd8
And one of my welder setup just to show you guys what I’m working with.
Dda2975ab487fa173deae7a298a1e068
Reactions: BigOL3
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
While you're at it reinforce the rear frame. The 2 rear stub rails are about 24in. I cut the flat plate off the bottom side of that last 6 Inches that's angled up by the hitch. Then welded in a piece of tubing that fits inside the rail. Hard to explain I'll try to find a picture.
Reactions: JTW
Dchilds75080
40
65
Richardson, TX
Since I’ll be burning all this in on the frame there at the back, you think that gets the job done?
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Not the best pics but you can see where I welded. I welded In a nut to bolt the rear bumper to.060483e3781fa8b0fde8a4a952663945Dcfc5f5bcc0fd0bce5e28c430b320638Ace095d391748a30a72901749989e9de3ff0ca0f714ce96b01894d4f631a9a878b4338f333c9c7120d7a81c721935228
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I think it's a great start and your welds look good. Since you know what you're doing and already gonna need some spray paint, might as well reinforce the lower rails. I think it definitely helps. And wont cost 10 bucks for a little steel. I think I used 1in square tubing.
Reactions: JTW
Dchilds75080
40
65
Richardson, TX
That’s what I have... did you get the aluminum spool gun?
No, I don’t have one. I don’t know how much use I’d get out of it. Do you have one/use it much?
Yes.. for the money and ease of use it’s a nice addition. Between boats, trailers and a host of other aluminum stuff.. it’s been worth it to me. Just can’t use the same gas for aluminum.
Hopefully I’m not too late but this may be a good time to consider a rear winch mount which also supports the hitch.
84e2763a4dd2c48dceb1ec8fc289636b
D1377708cef72d1cff3c620c9e993991
It ties the top of the hitch into the frame above it.
Dchilds75080
40
65
Richardson, TX
Reactions: joeymt33
Chevy412SP
Chevy412SP
102
126
Western New York
Nice job on the mounting bracket. Do you have the factory muffler or after market muffler to get the clearance for the winch? Also what size winch is that? I picked up a 4500lb winch on clearance at TSC for only $75 and really want to mount it back there but don't have the room to do it. Just wondering what setup you had back there to make it work.
Had to use a aftermarket muffler and there’s plenty of clearance as it has been on there for a couple years with no issues.
It’s the Honda 4000 which is the same size as the warn 4000 and 4500.
@knuckledeep makes a nice winch mount that works with factory muffler.
@ohanacreek has one and will probably show a picture
Reactions: knuckledeep
Chevy412SP
Chevy412SP
102
126
Western New York
Would love to see pictures of @knuckledeep winch setup. Not interested in having to go with after market muffler if I don't need to. Don't want the machine any louder. My days of loud machines are gone.
With HMF
FE065590 6421 477F 90E4 6A6959465124
6D266D80 8DD0 4DDF 810A 64B431559D85
70878B2F 2559 4B32 881F 6EC50CC6183B
C68874B0 EDCD 4706 9F63 2B7904AE2318
@knuckledeep ‘s mount
C88FCDC4 E86B 4D3A 9343 17849D0AD9C4
It’s sticks out but it’s only hit a couple of times and that was on fairly extreme black trails.
