P1000m5 XS Power Battery
HondaMarc
HondaMarc
10
29
Dallas
I looked at an Antigravity lithium battery, but the customer service said this, regarding a winch ...
Lithium batteries have only 1/4th the capacity (AH) as their lead acid equivalent. Given this anything outside of stock for the UTV would not standardly be recommended. You may look into a secondary deep cycle battery that would be better suited to run your secondary devices.
So, looking everywhere as I'm disappointed in the Odyssey
The
Odyssey dimensions, which fits perfectly:
6.64"D x 7.05"W x 5.04"H
XS Power Batteries
D925
550 CCA 28 amp hours
LxWxH6.5 x 6.93 x 4.92 inches
XS Power PSX 14 (recommended by XS power, the manufacturer) for the Honda Pioneer 1000-5.
CA: 240, Ah: 16
Length – 5.91 in
Height – 5.79 in
Width – 3.43 in
Is anyone running the XS Power brand?
And, has anyone run across a brand named ENERGEE? They seem to be used in high energy demand and heavily used car, boat and other audio applications.
Thank you
DRZRon1
DRZRon1
865
2,807
PA
we (I) am disappointed as well as you didn't post pictures of your ride - you could be asking for a friend
imo - its a freaking battery, for 98.5% of us (maybe not yourself), winching is infrequent, any descent quality battery will work - good luck in your evaluations
use the search bar up top - batteries have been discussed and debated at extreme nauseam levels
Reactions: JenElio
bumperm
bumperm
1,851
6,656
Gardnerville, NV
Sounds like their customer service reps don't know their a$$ from an amp meter.
"More Hours of Power
Lithium batteries provide 100% of their rated capacity, regardless of the rate of discharge. Lead-acid batteries typically provide less usable energy with higher rates of discharge. They are usually limited to 50% of the rated capacity to prevent diminished life."
Lithium batteries are quite happy being completely discharged now and then, but will last longer if stored at 40% to 60% charge.
Now having quoted that, I'll point out that many lithium batteries have a BMS (battery management system) on board that limits max current output, guards against overcharging, and keeps cells balanced. So, the battery you choose, if it's a lithium, should be intended for vehicle service. Lithium Ferrous Phosphate (LiFePO4) batteries have a bit less energy than Lithium Ion, but are safer and much less prone to require emergency fire department visits.
HondaMarc
HondaMarc
10
29
Dallas
Thank you very much, bumperm.
Your information is greatly appreciated.
Battery technology is changing and new research to come will surely be surprising and benefit anyone needing portable power.
Reactions: bumperm
