P1000 Yet another wheel and tire thread.
Itsalljake
Itsalljake
141
50
Los Angeles
So, believe it or not, I'm still on the fence about going Deluxe. One big reason is the tires. As I've mentioned before this will be a ranch bike in coastal California. unfortunately not tremendously rainy, which means not much water or mud. But some blacktop time between gates.
I want a tough tire. I want an especially roadworthy tire because of the road/pavement travel. The rest is dirt and climbing, but I don't want my pants down when I'm crossing the ocaisional stream. Leaning towards a BFG AT/OR type. Radial, aggressive tread, that's wears well on the hard road and maintains aggressive tread.
Drawn to the MotoClaw but the 15" wheel size needed to hit 28" seems weird to me. Must add that this is to avoid Deluxe prices and be able to upgrade my wheels to exactly what I want.
Thoughts?
267,227
The Katani Mongrels are DOT approved and would work well for the environment you describe, a great all around tire that doesn't excel in any one area. Also similar are the new STI Chicane also DOT approved but they are proud of them.
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
I love the title of this post!!
Reactions: Itsalljake
Itsalljake
Itsalljake
141
50
Los Angeles
"Kanati" mongrels apparently. Good looking tire Jackal, thanks. I'm still hoping for a slightly deeper tread so it maintains bite after some street wear, but I like the aggressive sidewall tread. Guessing they come in 28"(+) 14" wheel sizes. Will investigate.
Reactions: pct
Itsalljake
Itsalljake
141
50
Los Angeles
I support any STI tire.
Can you recommend a 28" STI tire for my application? The Rocktanes don't exactly fit the bill. I also must admit they look like a softer tire that may not wear quite as long around pavement.
Itsalljake
Itsalljake
141
50
Los Angeles
Holy crap, I think it's the Chicane. Thanks, again, again, again Jackal. Think I've read nearly every post on this site and your advice seems to be spot on every time. Pics when the build starts. Thank you gentlemen.
267,227
Itsalljake
Itsalljake
141
50
Los Angeles
I just so happened to be looking at their site. Are you getting tired of the Thank You's yet? Another question while you're on, how would you rate this tread, on incline, under load in dirt to gravel to soft soil. It's a very hilly ranch and I plan on building new trails in what will be my already very wide and heavy p1k5.
267,227
With the dry environment in southern CA you should have all the traction you need with the Chicane RX the split knob design really bites on dry hard pack surfaces, it fairs just ok in sand and just ok on muddy surfaces, same with snow. Doubt you will have much of the latter. It makes a great all around tire for dryer desert type terrain.
Itsalljake
Itsalljake
141
50
Los Angeles
Excellent. I'll always have the steel stockers to adapt for different weather. Had a blast busting streams and dodging tree limbs this weekend in my in-laws Ranger. In the rain with no windshield (yes, rain inSoCal) while visiting the wild Mustangs. Can't wait to get a Honda and get back out there. Plotting my purchase, pretty sure I've got a somewhat trustworthy salesman. Yes, i just said that.
HondaTim
HondaTim
203
40
That's why I think I will go with the Moto claws for those just in case moments.
