P1000 1000-5 Deluxe factory wheel witdth specs
Scoop
Scoop
5,401
21,264
  3. Talon R LV
I always thought they looked like paddywaggons
Here's a 1930 Honda Pioneer. Of course, we know by the lettering that it's an LE and not a Deluxe ... 🤣 🤣 🤣
1641519618399
L
LarryAmboy
906
2,019
Castalian Springs, Tennessee
That spacer is recommended to help keep the same trac with the same size tire all the way around and to give u a slightly wider stance for added stability and to help with the slight rubbing in your steer u can get with the larger tires. Ill post a pic of mine with those and 30” tires.
now, for what your doing with ur machine, i recommend some LT tires. You wont have to swap them out, they ware great, are highly durable and 1/2 the cost. Just pic your poison! Basically the kind you like. Ive had them on mine 3 yrs now and still great and i have awesome traction in the woods, swamps and gave used them in Colorado and the Take over 3 times with no problems. just a suggestion.
View attachment 312114View attachment 312115View attachment 312116View attachment 312113
What tires are those? I’m currently on 28” Tensor Regulators. I have arched A-Arms, front and rear, and Elka stage 5 in the barn waiting to install. When I get them installed, I want to go to a 30” tire probably on 15” rims. Haven’t decided on the 14 or 15” rime yet.
116,572
There LT/MT tires.
Achilles Desert Hawks
Reactions: Lady01 and ChadD
Cajun-Abear
Cajun-Abear
49
141
Louisiana
Remington, I'm finding myself on the road a lot in the off-season and now I'm 100% sure that I want to go with the LT tire setup. Can you give your exact setup with the tire and wheel sizes? Also, any lift? (I can see the upgraded A-arms). I love the stance of your machine. The bike further away in your last pic appears to have smaller tires than you do. Thanks in advance buddy!
castleman1
castleman1
12
73
IF your are looking at these wheels(Maverick x3 takeoffs) I can tell you that with 2'' spacers in the rear and 1.5 on the front yu will be right at 64'' wide front and rear. I bought mine used and it had some aftermarket rims that were wider in the front so I cant say what width factory rims would have been. I waited to find a set with 8ply 28'' big horns and the wont rub with factory suspension.
PXL 20220207 185648824
116,572
The tires are 30x10x15 and the wheels are MSA Loc’s
I have 1-1/2” spacers in the back and 1” in the front.
SATV arms and fox shocks And i use the preload of the shock to get my lift as well as the arms.
no bracket lift. Messes with the geometry of the machine And rides like crap. Had one and you dont know the difference till u go back from it.
Cajun-Abear
Cajun-Abear
49
141
Louisiana
Thank you! I would imagine that you get many more tire selections in a 15" wheel instead of a 14". I may go with a smaller tire as I'm not quite ready to dump that much in the buggy right now. Other toys need attention too!! lol
