P1000 1000-5 le
WagginTail
WagginTail
1,585
5,880
SC
The back door, water, and mud come under the bottom side. Does anyone have a fix for this?
Do you mean from driving through water that deep? Or water and mud being slung up from the tires? If coming off the tires then I recommend some mudbuster fenders.
WagginTail
WagginTail
1,585
5,880
SC
I got the XL.
W
WR Timber
5
Oregon
115,818
Welcome Bro from the Now Libtard State of Michigan!
Ill tell you what, thats one hell of a first post! 🤣 Did you know that you bought a SXS? They have water gaps and spring leaks like a first date in High school!🤣😂🥳
How about some info on this rig of yours? We think u have an LE from the Thread title, but what year, color miles and mods? Oh yea, cant forget the pics!! Oh the ever so absent like a hot potato pics!
Pics Or It Didnt Happen!!!! ;)
Also, try that search up top for more solutions to your leaks! 🚱
Dirtstiffs-1000
Dirtstiffs-1000
1,669
6,076
hondasxs.com
Mud Busters XL will stop most
20221001 174801
bumperm
bumperm
1,906
6,788
Gardnerville, NV
The MudBuster fender flares come with self drilling sheet metal screws to fasten the very rear of the flares to the frame. I decided I'd rather mount them with rivet nuts, which I installed first into the frame. Shown below, I've made two 5mm threaded points (used the excess threaded length cut from the door storage mod ball ends. The taken to a point using a drill motor to gently hold the threaded shaft against a grinder). Next the fender flare forward mounts are secured and then the flare is smacked gently up with a mallet or similar so the threaded point will precisely mark where to drill the hole for the attach bolts.
20220428 212554
