P1000 1000-5 vs 700-4 Deluxe
kaspar139
kaspar139
37
98
Conroe, TX
Damn it! I have a deposit down on a 700-4 deluxe, but with a roof it won’t fit in my garage. Getting the shorter by 2” 1000-5 with the better power/capacity sounds great, but not the extra $4K. It’s also almost 4” wider and will be tight in my garage. I am almost to the point of flipping a coin!
Reactions: Lady01 and TripleB
Russ989
Russ989
22,565
146,497
If you don’t plan on trail riding it, the 700 is fine. I had one before I bought my 1000-5, it’s a solid machine.
Robobrainiac
Robobrainiac
2,457
8,553
Flip the coin. Let's say heads up is 1000. Let's say it lands on tails. If you were disappointed then you know your own answer. You should have gotten the 1000.
I have a 1000-5. LOVE IT
My wife and I looked at the 700 and the power, speed, towing capacity of the 1000 beat the 700 out of the water. Take both for a test drive and I think you will settle on the 1000.
someguy1313
someguy1313
170
372
SouthEast
I have a 700-4D and a 1000-5D and love both units. Your best choice is dependent on you usage. I use the 700 for hunting. It gets into smaller spaces with less problems. I have 27" Mud Lites on it and power is not a problem. Pulls a trailer with 2400# of firewood with no problem. The 1000 is more of a cruiser for me. Much better ride and smother engine response. I do like the low range and wish the 700 had it, but don't underestimate the power of the 700. I also like the Turf Mode on the 1000. I wish the 1000 had a hand brake like the 700. For me, top speed isn't an issue with either as I rarely get over 25-30MPH on either. Choose your vehicle based on it's intended use.
This right here.
I have both.
Depends on usage.
for farm and field the 700 will do all you need.
for trail riding w/ your crew, the 700 will work, but the 1000 is more of a pleasure.
so many factors.
Test - Grid
