P1000 1000 Honda pioneer wheel bearings.
bumperm
bumperm
1,918
6,806
Gardnerville, NV
Good to keep in mind that some greases and oils are incompatible with others. This is true of both the oils in grease as well as the thickeners. If in doubt, best to clean out all the old grease before re-greasing.
208,813
Just don't use gas to wash them out, it cuts the finish off the bearing surfaces and will fail pretty quickly.
bumperm
bumperm
1,918
6,806
Gardnerville, NV
There are some good, explosion and fire reasons not to use gasoline as a solvent, but I've never heard that. The steel in bearings is not generally porous, so I can't see a problem with removing a finish. What finish would that be that could be removed with a simple solvent? Can you point me to a reputable source on this - I searched but found only one or two saying volatile solvent fire risk.
Plowboy1466
Plowboy1466
300
1,502
Ashland, Ohio
I could see where the gas would deteriorate the seals, but not the hard finish on the steel.
Reactions: Lady01
bumperm
bumperm
1,918
6,806
Gardnerville, NV
Exactly. Assuming one is removing the plastic or rubber seals prior to cleaning, I've never heard of a problem with any common hydrocarbon based cleaning solvent.
Reactions: Plowboy1466
Ohio4x4
Ohio4x4
I brought the dishwasher
1,530
15,442
Ohio
Wow.
That's not common.
What and where are you running?
I have the same trouble. Only with the rear. Its becoming common to change them with the oil. The current ones were installed before the mom2 ride and they already have play. I've tried all balls pivot works and the oe honda part. It doesn't seem to make a difference. I've chalked it up to the load of s*** a carry with me and the beating the machine gets.
208,813
Do you happen to have part numbers?
I do not, I've only got 4,000 miles on mine and mine haven't gone out yet. Take a bearing with you, the industrial supply will measure them and get you what you need.
Reactions: Lady01
Dirtstiffs-1000
Dirtstiffs-1000
1,699
6,153
hondasxs.com
I wouldn't be afraid to install these.
All Balls Racing Wheel Bearing Kit 25-1728 Compatible With/Replacement For Honda Pioneer 1000 2017-2018, 1000 LIMITED 2017-2018, 1000 SXS1000M3 2016, 1000-5 2016 2017 2018 https://www.amazon.com/dp/B06XS39BNV/?tag=sxsweb24-20
highpocket74
highpocket74
2,080
6,839
Kinder, Louisiana
www.10-80dirtsports.com
I sell 4xpro bearings and axles. So far no customer complaints on either and they seem to be good quality. I've used these and all balls on my Polaris machines in the past and both outlasted the over prices OEM bearings.
In stock and ready to ship if you need them.
bumperm
bumperm
1,918
6,806
Gardnerville, NV
Reactions: Lady01 and Ohio4x4
Ohio4x4
Ohio4x4
1,530
15,442
Ohio
I had great luck with all balls in the atvs. I'm probably f***ing something up.
Lady01
Lady01
192
488
Midland Michigan
I have alot of wheel bearings issues. what is the best wheel bearings?
Hello All,
Good responses. While I have NOT had wheel bearing issues on my '19 P1K-3 I have had a number of them go bad on my automobiles. I have watched this thread for a few days and have been reluctant to share my story because...well it is just a stupid thing, read below and hopefully this will help.
Information: I am an ASE cert. master automotive mechanic, do all of my own work (well nearly all).
Story: I have an '07 Ford Edge (approaching 500K miles) and a few years back it seemed as though I was running through wheel bearings, 30,000 - 50,000 miles, they just wouldn't last! I too thought what has been discussed on this forum, bad manufacturing/material, bad batch (it does happen), lack of grease, etc.
One day while driving I heard those front wheel bearings humming again. That's it! I decided to take my time disassembling cleaning installing (press fit) and re-assembling, finally I pulled out my torque wrench and light bulb!!! in my haste previously several times, I started using my "ear and feel" from my impact gun instead of torquing properly. It's now going on 150K miles, (on Advance Auto wheel bearings) and still going strong.
Lesson: Stupid mistake on my part by NOT following each step. It's easy to be overconfident in your own craft and skill and very easy to take short cuts. I learned (re-learned) the hard way that proper torquing is an important step that I had been ignoring. That's my story, hope it helps.
Ohio4x4
Ohio4x4
1,530
15,442
Ohio
Hello All,
Theres probably something to that. I've gotten so used to just using my best judgment that it don't get the torque wrench out often. I too used an impact or breaker bar to put the axel nut on.
