P1000 1000 Honda pioneer wheel bearings.
Lady01
Lady01
192
488
Midland Michigan
Theres probably something to that. I've gotten so used to just using my best judgment that it don't get the torque wrench out often. I too used an impact or breaker bar to put the axel nut on.
LOL, well its worth a thought at the very least!
Reactions: Ohio4x4
bumperm
bumperm
1,929
6,828
Gardnerville, NV
I learned something too, though I'm a fastidious user of torque wrenches as I work on my aircraft too - and you can't just pull over to fix something.
What I learned is about over-greasing bearings, causing grease to churn with resulting heat friction and wear. I did know some greases are not compatible with others, so cleaned the bearings grease free, before re-greasing, when in doubt.
Reactions: Ohio4x4 and Lady01
K
Kilpy
Fort Wayne, IN
What I was told about not using gasoline to clean bearings, was that gasoline removed the oil film from the bearings, and seemed to be an impediment to, or resisted the replacement of that oil film on the bearings, thus shortening their life... The recommended cleaners at that time, (early 60s), were kerosene, or diesel fuel. Farm equipment bearings were the ones being discussed.
Vikes79
Vikes79
SKOL!
12,009
115,467
South Dakota
  2. Talon X4 LV
What?
You mean I shouldn’t use the 4’ breaker bar with a 10’ cheater pipe on it to install?
It’s what I used to remove it!
0860silverado
964
1,862
louisiana
Also... never EVER allow the bearing to spin (at all) while using compressed air to blow out old grease and solvent.
Reactions: Lady01
