I’m having the identical problem.
2018 P700-4 Deluxe bought Nov 19 used.
I bought the sub-harness from the store to provide a switched source. I can’t even find that plug coming from the cig lighter outlet that it's supposed to plug in to.
Looks like the power steering is tapped off of it????
Does anyone have a pic of that ACC fuse box wire you were talking about OR a picture of that plug for the sub harness that provides the switched power lead sold on this store???
One more question.
If I finally find a switched source, can I mount a six pack terminal strip and use it for all the relays and switches????
thx
Newbie😩😩
I never did find a plug after pulling half of the machine apart.
What I did though was to tap into the 12v wire for the acc. plug that is directly below your shifters.
The lead for that comes down in a smooth plastic wire covering that is zip tied to the frame crossmember right in the center under your hood.
I used the white/black tracer wire as a switched 12v source for my switches to trigger the relays.
There is nothing running off of the power steering that I can see, I also wouldn't tap into anything to do with steering or safety as a small short or backfeed when unexpected can cause a rather big issue either to a possible accident or financially or both.
Let us know if you need anything else, I will help as best as possible.
Lastly I am not fond of Stak-On connectors as a result every connection I made is soldered and heat shrunk with the exception of the back of my switches.
