What brand, model, are you usingI highly recommend the bed liner. For what your doing its alot better than the bed mat. Ive had one on my 16’ since it was fairly new. Takes a beating and nothing under does. Easier to clean out also.
The Honda one.What brand, model, are you using
Show offThe Honda one.
I havent seen an aftermarket one.
zoom in, you can see it. Sorry best pic I was able to find
Started out checking Monthly, then kinda gradually dwindled over time, never added oil, I’ll pull stick tomorrow n see, been at least a year . Curious myself nowI'm curious with those 5000 mile oil change intervals - how often you checked your oil level, and if / how much you found yourself adding between changes.
Gn4 10 30Also what brand oil?
You’ve barely got the velvet worn off of that bed linerThe Honda one.
I know right?You’ve barely got the velvet worn off of that bed liner
Still full of oil, tried to take pic but it wasn’t visible on camera , honestly can’t remember the last time I changed it or checked it. So definitely not leaking or burning oil yet. Also checked, 2837.2 hrs on the clock. I don’t do W O T driving, mostly 20-30 mph, anything over that is uncomfortable for me. Sure that has helped lead to longevity of the engine toI'm curious with those 5000 mile oil change intervals - how often you checked your oil level, and if / how much you found yourself adding between changes.
That should calculate to an average of 7.12MPHStill full of oil, tried to take pic but it wasn’t visible on camera , honestly can’t remember the last time I changed it or checked it. So definitely not leaking or burning oil yet. Also checked, 2837.2 hrs on the clock. I don’t do W O T driving, mostly 20-30 mph, anything over that is uncomfortable for me. Sure that has helped lead to longevity of the engine to
Howdy from Oklahoma and welcome to the club. You sure got your moneys worth out of that one!Signed up here awhile back just to look around, thought I might tell a bit about my experience with 16 1000-5 deluxe. I’m now at 20200 miles, I don’t trail ride or mud ride, tho I often do drive thru mud on the farm. Other than my own neglect, It’s been bullet proof. Always seem to be in a hurry so on multiple occasions before I stopped completely I’d shoot for neutral and find reverse. I stripped the reverse gear around 5000 miles, had it rebuilt,but stripped it out again shortly after so for the last 15000 or so miles I’ve drove it without reverse.I replaced brake pads at 16k,rear bearings at 18k starter motor at 19k. Now the shifter cable is broken so it stays in high full time, driver side of seat is worn out , floor board is shattered ,step rails are gone, driver door gone, needs replaced or maybe bushings, on 3rd set of tires. I ve never opened the air filter box,not once,only changed the oil four times, but it’s still running as good as when new. I no my maintinance schedule is harsh, but that’s why I only buy Honda’s, they are the best on earth. I run it 7 days a week, I’m going to try and upload pics of it and it’s new replacement. What if anything I wanted to show was that riding on gravel, the rocks have eaten the step rails completely away, I have some cheap mud guards ordered to put on new sxs For protection of side step rails. Zoom in on pics so you get an idea
View attachment 349051 View attachment 349052 View attachment 349053
Hello, thanks. HopeHowdy from Oklahoma and welcome to the club. You sure got your moneys worth out of that one!
Where are you at in SW Arkansas? I was born in Magnolia and lived there when I was a Kid. Still have some family ties there.
BTW, blue is the coolest color on a Pioneer. View attachment 349175
How does it ride on those tires?I got the ricochet rock sliders to help keep sticks from busting the floorboard and firewall (already had it happen before) and they will prevent rock wear from happening. Easy install. You can see them in the second picture. I like that color too. Mine used to be camo.
Good looking rig, I like your color n tires to. What year is your pioneer? Went to ricochet site an looked at em , I’d say that’s the best way to go from what I can see thanks for sharingI got the ricochet rock sliders to help keep sticks from busting the floorboard and firewall (already had it happen before) and they will prevent rock wear from happening. Easy install. You can see them in the second picture. I like that color too. Mine used to be camo.
View attachment 349206View attachment 349207
Ricochet rock sliders not available for 2022 p1k5 yet, I called them to check, looks like I will be waiting. They said they hadn’t had a 2022 in their shop, so maybe it’s the same as previous models? Anybody know? Never mind, I compared it to my 16, maybe more to it, but the front fender well plastic for sure is differentI got the ricochet rock sliders to help keep sticks from busting the floorboard and firewall (already had it happen before) and they will prevent rock wear from happening. Easy install. You can see them in the second picture. I like that color too. Mine used to be camo.
