2015 honda pioneer 700
L
LJY Red Bluff
Red bluff ca.
Hello ,new here.
I have a 2015 honda pioneer 700.
Will run for about 15 or 20 minutes and dies.
It usually takes about a half hour of waiting and starts again,but will die and do the same thing.
I replaced fuel pump,fuel relay plug,coil ,plug boots. All oem parts.
Last time it died I pulled a plug wire immediately and checked for spark with a extra plug that I had. No spark.
It is like something gets up to running temperature and switches off.
Any advice much appreciated. Thanks.
Reactions: 500oneer and TxDoc
HondaTech
Pulse generator is probably getting hot and not firing the coil.
Next time it dies, check both sides of the 2 pin pulse generator plug for continuity to ground. They should open circuit.
If that checks out, youll need a peak voltage tester or adpater to check for output.
L
LJY Red Bluff
Red bluff ca.
Thank you very much.I will start researching pulse generator, first I have to locate it. L. J. Y.
L
LJY Red Bluff
Red bluff ca.
HondaTech , I can't thank you enough . Saved me a ton of time. L.J.Y.
