P1000 2016 1000 trans issue
T
Tahoe1
Mid Missouri
After a day of work my Pioneer would not go in to gear. When put in R, H or L the gear indicator displayed 2. I towed home disconnected the battery over night and the next day it worked for about 5 miles. As I was dring in H about 15mph it just went on to neutral. Before turning of the key I saw the display flashing g 5 slow and 7 fast dashes. This time the indicator displayed 5. I towed home and took to dealer. Of course now it will not act up for them. Any suggestions or experience with this issue would be greatly appreciated.
Neohio
Neohio
Beast of the East
17,948
86,649
Painesville Ohio
Your dealer should be able to diagnose and test components based on your code of 57.
1647532438309
Look for hidden rodent damage to the wiring. That would be my first step, then get a service manual and follow the testing procedure.
The dash will not tell you the difference between a 57-1 & 57-2. So run thru both testing trees before deeming any part failed.
115,818
What @Neohio said. Plus Id check my linkages As well.
No pics from your only 2 post. said u had 8k miles on it from your first post. definitely Pics Or It Didnt Happen… 😂 How many on it now?
Reactions: ChadD
T
Tahoe1
Mid Missouri
Thank you. I will.
Reactions: ChadD
