Transmission Issue
JenElio
JenElio
82,147
714,160
Loxahatchee, florida
I found the code in the manual and went through all the steps checking for voltage, opens and shorts. Everything checked out. I just pulled the shift motor, planning to put 12 volts on it, then reverse polarity to see if it works in both directions. But as it turns out no need. Shift motor is shot. Pretty grindy and the shaft is all sloppy. Now question is how quick can I find one
Try ronayers.com
906UP
906UP
15,015
142,633
da Yoop
Amazon has them as well, I needed one in a hurry for OG Donkey and got one from Bald Bezos
Backwoods
Backwoods
37,509
374,233
Douglasville ga
How does a thread relating to transmission issues morph into this? Seems like someone needs to spend more time like Gavin servicing their own tranny
My question is why are you doing that while watching Biden ? Isn’t there at least an animal show on ?
Jerryg
Jerryg
12,248
96,687
NEPA
🤔I welcomed him back already in another thread just like I said I would. 🤷🏻‍♂️
Gay
Hello_Darkness
Hello_Darkness
666
2,677
Just to the right of nowhere
I found the code in the manual and went through all the steps checking for voltage, opens and shorts. Everything checked out. I just pulled the shift motor, planning to put 12 volts on it, then reverse polarity to see if it works in both directions. But as it turns out no need. Shift motor is shot. Pretty grindy and the shaft is all sloppy. Honestly, I'm surprised it was working at all. Now question is how quick can I find one
Sorry for not getting back to you, I was going to suggest removing it and checking it's "feel" if you hadn't already
I've been stupid busy
Hello_Darkness
Hello_Darkness
666
2,677
No worries man. Figured I'd just dig in and figure it out. I try to always ask on here though. Not much that someone on here hasn't seen.
Sent from my SM-S911U using Tapatalk
Only enough I've yet to see this issue in person on a Pioneer, though it seems several on here have had this exact failure.
BrophyCreek
BrophyCreek
520
3,246
New Richmond, WI
I'm curious as to how exact. Up fine, but no down shift? Or just random shifting issues? Also intermittent? I would think so on that as motors can get bad spots, so to speak. Especially steppers.
