P1000 Water in transmission oil
Neohio
Neohio
Beast of the East
21,739
93,106
Painesville Ohio
5,744
26,370
Oil (left) first sub-trans oil change. Oil from third oil change (right). Using Shell Rotella T-6 oil. Will this clear up with more changes? Suggestions?
View attachment 438765 View attachment 438766 View attachment 438767
Note that if there's frost on the outside of your engine, there's frost on the inside; that's why it's so important to get them up to full operating temperatures - to burn off the condensation. The colder or more humid your environment, the more important this becomes. In really cold temps, you should be blocking off your radiator until the fan starts cycling normally. You'll have to experiment with how much blockage for your area and temps. eta: you don't need frost to have internal condensation.
Reactions: Backwoods
Bayouownbeer
Bayouownbeer
798
1,123
Chauvin LA
Can you provide a link to extension kit?
Message me for better deal than on eBay. Here are the links
Honda SXS ACC link
This is the vent extension kit thousands of members have used. Includes everything needed to extend all 6 vents with black tubing. No sourcing out parts or multiple trips to the hardware. This includes first class USPS shipping. Instructions and tracking will be emailed.
BLACK TUBING ITS HARLY NOTICEABLE IF IT’S RUN RIGHT
Screen shot Reviews on my page in the feed
https://m.facebook.com/Hondapioneer1000seatheatsolutions/
Vent extension kit without filters recommended for 5 seater. Filters not needed your preference. Simple hour install. Great piece of mind knowing your covered.
THE ORIGINAL Honda Pioneer 1000-5&6/700/500, Talon Vent Ext. Kit Without filters | eBay
With filters recommended for 3 seater pioneers and the Talon. If you don’t heavy mud you can use the kit without filters and simply turn the ends down 90 degrees.
THE ORIGINAL Honda Pioneer 1000-5&6/700/500, Talon Vent Ext. Kit. With filters. | eBay
Both heat shields and vent kits package without filters
Honda Pioneer 1000-5&3 Heat Shield's 1&2 + Vent Extension Package Without Filter | eBay
With filters
Honda Pioneer 1000-5&3 Heat Shield's 1&2 + Vent Extension Package With Filters | eBay
Just heat shields. This material is construction grade material very thick 5/16” and durable. Fire class 1 rating
Honda Pioneer 1000-6,5 & 3 Seat heat Shield Part 1 and part 2 | eBay
Dirtstiffs-1000
Dirtstiffs-1000
1,729
6,240
hondasxs.com
If your not familiar, flush and fill with oil would be good enough.
Your favorite oil, likely has a % Moly already added.
By definition -
Honda Moly Paste
Moly coatings lubricate sacrificially by transferring lubricant between the two mating surfaces, which helps to reduce wear and coefficient of friction. Molybdenum Disulfide (MoS2) coatings are a dry film lubricant.
Reactions: Rayger143
