P1000 2016 Pioneer 1000 shorting DLC to clear codes
V
VinnyC
5
6
Lima, Ohio
2016 P1000
I bought a service connector jumper to clear codes with but I wanna make sure it’s pinned correctly so that I don’t short something out, anyone know which two wires on the DLC connector on the machine are the correct two to jumper out?
Thanks
Reactions: Lady01
HondaTech
Anything with the 4 pin red connector shorts the same 2 pins.
Everything up until the Live Valve Talons, and some newer street bikes use this same setup. The new connector is a 6 pin with CANBUS, but they still short the same colored wires i believe.
Reactions: Lady01
V
VinnyC
5
6
Lima, Ohio
This is a four wire connector, the way this ones wired the jumper connector I have is gonna short the solid res to the solid green and not the brown w a red stripe
565F6699 1AE8 4F98 9C09 61761B106B11 E00609B0 90C5 43BC A85B DFDCDC562E9A F0434F9D 7C04 4B84 A3BF 09BAB5F9359B E191F88F 7F05 4664 843F 0EF3ED4198A8 549C714F 5D7B 47E2 846F 824B17A7410E
Reactions: Lady01
V
VinnyC
5
6
Lima, Ohio
Top pick is the two wires it’ll be shorting, so is it possible I need to re pin the jumper connector? I have not tried it yet in case this is incorrect and by from what I’ve been reading it isn’t right
HondaTech
With the clip holding the connector together facing up, it should short the two left side wires.
Your connector is wired correctly
Reactions: Lady01
Jody phillips
Dixon mo.
When doing this, once connected what do you do ,next turn on the key?
Reactions: Lady01
