P500 2017 with 25" or 26" tires
AlR
AlR
470
1,166
Nanaimo, British Columbia
I'll phone Moose.
Sui
Al
Had to email Moose Racing. Asked if the "maximum torque spec of 25 to 30 ft lbs" sticker was important... Here's what they said:
Screenshot 20170804 134152
FYI
Al
NitroxDiver
NitroxDiver
488
918
Concord NC
Thanks for messaging them. Now I don't know what to do. I'm very surprised at that torque spec.
U
uconn411
160
255
CT
So I have a 2017 P500. This weekend in NH, I bashed the front bumper / skid plate pretty good going over some rocks. I’d like to avoid that. Any recommendations on new tires. Taking into consideration that I want to gain ground clearance while not being overly tippy. Also if possible, I’d rather not be covered in mud from the tires sticking out from the oem wheel wells... My primary riding is trail riding, I avoid going through any deep mud. Mostly dirt and rocks and some paved roads...
NitroxDiver
NitroxDiver
488
918
Concord NC
I picked up these tires from Chaparral. They only come in 25" so that made my decision easier. The price for all 4 was $219.00 no freight no tax. They are a knock off of the original big horn knock off the GBC Dirt Tamer. The tread is exactly the same as the Dirt Tamer (in appearance). They measure a little over 25" at 7PSI so I would call them a true 25" tire. They are 6 ply rated bias. I mounted them up over the weekend and went for a short ride, so far so good. The cases feel strong and I think they will be durable but time will tell. The way I see it if they last 50% of the Big Horn or Dirt Tamer I will brake even if they last longer its an even better bargain. So far they ride, look and handle much better than the stock tires.
Update on these cheap tires. Not really a long term review but I have put about 300 miles on them and so far so good. I'm running 7psi I have had no flats or punctures. I have ridden several miles on hard top and they are holding up well. They are not cutting or chunking on the sharp rocks. They ride smooth and handling is good. If they continue to wear this well they are going to be a bargain.
Reactions: HUCK
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
I put 26s on my 2017. Before I ordered my new tires, I had the same concerns about climbing as you. Let me put your concerns to rest. I just got back from Moab, my P5 climbed up grades that were unreal. I had never climbed anything steeper with any of my previous rides. Plus the added ground clearance. Would buy 26s again!
How did your P500 do overall in Moab? I’m considering taking mine up there.
V
vinnie55
dubuque ia
I had 26x9x12 Roctane XD put on my OEM rims day one and love them. They are about 2.75" taller than OEM tires, they work well in all terrain from rocks to very muddy trails.
Hi did you put the 26x9x12 on all 4 corners ? Stock rims ?
A
ayhanmecit
24
17
west hills, ca
I now use the 26" tires (Maxxis Big Horn 2.0) with no problems or concerns. They run through sloppy, muddy water high as the top of the tire. Sand is not a problem. No rubbing. I did go with 1.5" spacers, in the rear only. The rear width is now exactly 53" and the front is still 50". I do not have a fear of tipping or bogging down. My top speed remains at the governed 40 MPH. I was hoping for a little more speed with the 26" tires over the stock 24" tires but it did not happen.
What width tire up front and in back? Did you put those on the stock wheels or aftermarket?
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
On my machine I did put 26x9x12 on all 4 corners. And yes, it did increase speed because the tires cover more distance when they're taller. The speedo always read 40 mph, but with 26" tires it actually DID go 40mph. Meaning the larger tire made the speedo accurate, where it reads faster than reality with the stock tires.
Reactions: J80
208,731
Looks great!
JimmyA
JimmyA
1,644
5,504
Northeast texas
Nice rig! Let her rip!
BURNDOG
BURNDOG
84
229
Oregon
Haven’t got tires yet but when I do I think I’ll go with these guys. Name pops up a lot and it’s always good....🤷‍♂️
Reactions: J80
T
THeck
87
221
Southeast, KY
  2. Do not currently own
I put 26” Originals on 14 in wheels. Rides a lot better with more clearance. Seems to do fine on hills.
