P1000 2019 1000-5 first service
RoundMtn
31
82
Maine
So the wife went on holiday ride yesterday and did almost 100 miles.
Time for first service.
Gonna drain both oil plugs and change two oil filters . Should I drain third oil plug too?
What else should I check on first service ?
RoundMtn
31
82
Maine
Valves ...really at first 100? Blah
Ok will do
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
3 oil plugs yes
208,013
The 14 mm front drain plug drains the sub transmission and to fill it back up the filler is under the front seat not in the rear.
Reactions: TripleB
I've never adjusted 1000 valves at first service, inspected plenty, but never adjusted. The exhaust are hit or miss down the road.
Reactions: Middy and helimech
AZRocks
AZRocks
111
217
Phoenix
Follow the manual. Change the engine/clutch oil by draining the two rear plugs and replacing the two filters.
The forward oil plug is the sub-transmission oil which needs a change after two years. Inspect the valves if the engine is noisy, that is, if you can hear clackity valves. I checked my valves and they were perfect. But I did get to know the motor better and ensure the air intake tubes and grounding points were properly tight.
JML1981
JML1981
12
Arkansas
Just checked mine at around 2800 miles and the intake valves were still within the suggested tolerance but had to adjust the exhaust valves. Luckily Because I think the I’m pretty sure you have to shim the intake side.
RoundMtn
31
82
Maine
First service done.
Windshield installed with basically no instructions because Honda sends no instructions with its products. Winch almost installed and thanks for You tube for great install video. I guess now it’s so easy I could do with eyes closed. Boot/a-arm guards are next.
F
firematt911
Hyndman, PA
I took my first change into the dealer, was told, they adjust valves and other things in addition to the oil. However, while I swear my dealership had a sign up that said $259 first service for months. When I took it is, swear saw same sign. When I went to pick up my 1000-3 there was one under said 1000 series $359. WOW. I hope they did more than put in some oil and kick the tires. I'll never know. They are def more complex than a normal car oil change even if that is all you are going to do.
Reactions: RoundMtn
RoundMtn
31
82
Maine
Ok all done... now just waiting for the roof...
Window ,winch, first 100 mile service, boot guards installed .... all done... was actually lotsa fun.
Now trails open tomorrow woohoo
meanmachine19
meanmachine19
16
54
Northern Arizona
I definitely picked the wrong profession and should have been a mechanic LOL. I am so mechanically declined I have little choice but to let the dealership do my first servicing. Not happy about the prices being quoted either, the lowest being $500. Talk about having buyer's remorse. This is my first SxS and we don't ride it hard at all like some of the crazy videos I've seen on YouTube or FB. I don't want a money pit for a hobby so I told my wife we need to start investing in the proper equipment to become a part time mechanic! I'll be a graduate of YouTube University in no time LOL. But seriously, I hope I get enough bang for my buck. We'll see after our first family vacation with the new SxS. Sorry for the griping, just venting over maintenance cost shock....
Reactions: TripleB and Mudwing
13,360
65,068
@meanmachine19
Take a look in this following thread.
You can get by working on your machine with minimal tools bought.
A few select metric wrenches and sockets and you can do 95% of the work you will ever need to do.
The bare minimum listed in the first post is what I would recommend you start with.
A service manual is handy to have as well. If you upgrade your membership to either supporting or lifetime member, there is a service manual thread with links.
meanmachine19
meanmachine19
16
54
Northern Arizona
@meanmachine19
Thank you. I will definitely look into these options over the weekend.
